xA: rim size help
Old May 8, 2007 | 02:10 AM
ddl2k3's Avatar
Default xA: rim size help
im getting new rims/d tires
16x7 with Avon tires 205/45/16 just was wondering if i'll have clearance for the brakes? do i need to know the offset for that?
Old May 8, 2007 | 05:44 AM
Subcompact Culture's Avatar
Yes, you'll need to know the offset. Also, why 205/45/16 tires? The correct size is 205/50/16; that will keep your speedometer and odometer correct.
Old May 8, 2007 | 01:15 PM
ddl2k3's Avatar
o ok would 35mm offset work?
Old May 8, 2007 | 01:43 PM
JSosa's Avatar
dont worry about the brakes, they will fit. As for the offset you should be fine. Im running with 16x7 and +38 offset, works fine no rubbing.
Old May 8, 2007 | 01:53 PM
ddl2k3's Avatar
o kool thank you
Old May 8, 2007 | 03:46 PM
ddl2k3's Avatar
is it bad to have 205/45/16 cause im tradin with someone and he has 205/45 on his rims already.. is it badd for the car? it says im going to go 58 when my speedo reads 60
Old May 8, 2007 | 06:53 PM
Mechanically it'll make little difference other than the speedometer being a tad off. However, it might not look as good because the sidwalls are going to be thinner creating more wheel gap.
rain7905643
Mar 14, 2015 12:48 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
Genesis
64
Jan 22, 2005 01:02 PM
