NEED HELP retrofit question harness!
Old May 10, 2007 | 03:41 AM
haiduy's Avatar
Default NEED HELP retrofit question harness!
so i bought the retrofit headlights off extc and now its all installed but my headlights wont turn on , is it because i dont have a relay harness to draw power from my battery or d2s harness?!?!?! i even got a test ballast from au2tek to test it out but it still wont turn on i dont get what the problem is its not the fuse checked that nothing broken and i didnt miss any plugs !! can anyone help me? i thought hids dont really need a relay to even use it!
Old May 10, 2007 | 04:06 AM
Yanki01's Avatar
check the fuses 1st. what do you have to get power from, is it just wired into the low beam sockets? If so you need to get a relay and this is what mine looks like.
Yellow and Black wires to ballast, red and black to battery and blue to low beam.
buy it by emailing someone at the bottom to make you one...
http://www.hidplanet.com/forums/viewtopic.php?t=20144
if you can, bench test your ballast to make sure you didnt reverse polarity your ballast. What ballast do you have anyways?
Old May 10, 2007 | 04:08 AM
STNC's Avatar
what is extc?
Old May 10, 2007 | 04:35 AM
haiduy's Avatar
hes a guy on sl haha thanx yanki i know you did the retro fit so ima get 9006 relay harness and try it
Old May 10, 2007 | 05:29 AM
Noodle's Avatar
What ballast do you have? maybe some pics of the setup might help
Old May 10, 2007 | 05:36 AM
haiduy's Avatar
i bought it from exTc i think you made it noodle did you not lol i dont know im pretty sure you did tsx projectors bmw e46 shrouds
Old May 10, 2007 | 06:48 AM
ricexizxgood's Avatar
Yea, you're gonna need the relay harness.
Old May 10, 2007 | 06:49 AM
check out hidplanet.com if you need the harness
Old May 10, 2007 | 07:06 AM
haiduy's Avatar
thanx im hoping to get one this weekend
Old May 10, 2007 | 03:22 PM
Noodle's Avatar
Yep. I retroed that. What ballast do you have? Try taking the bulbs out and test them with the ballast. Make sure you plug the stock 9006 socket to the ballast correctly , - to - and + to +.
Old May 10, 2007 | 07:21 PM
haiduy's Avatar
i got the ballast he used the mcculloch and i have another one to test and they are GHC by au2tek both dont work
Old May 10, 2007 | 08:29 PM
Noodle's Avatar
I can't really tell unless you post your pics of your setup bud. Also, make sure you test both bulbs and see if it is the bulbs. If the second bulb doesn't work, then most likely it is the setting or that one ballast.
Old May 11, 2007 | 05:40 AM
ExTc's Avatar
I advised him to get the harness the first time he told me the retro would not ignite. Most tc's cant even power up HID ballast without a fuse and relay harness.
Old May 12, 2007 | 07:53 AM
haiduy's Avatar
ima get it tomrorow and try it out thanx guys
Old May 17, 2007 | 04:03 AM
haiduy's Avatar
well i got my relay harness today im going to try it tomrorow but this thing does look complicated to hook up T__T
Old May 17, 2007 | 04:41 AM
Yanki01's Avatar
any pics, does it look like mine?
Old May 17, 2007 | 04:48 AM
haiduy's Avatar
yea it does ill tkae come pix in about 10 minutes
Old May 17, 2007 | 05:06 AM
haiduy's Avatar
here are the pix of what it looks like
Old May 17, 2007 | 05:25 AM
Noodle's Avatar
here, I labeled them
Old May 17, 2007 | 05:26 AM
haiduy's Avatar
thanx love you guys will do it tomrorow morning asap !!! haha maybe tonight at midnight
