Rough Idle question at start up
Old May 11, 2007 | 03:51 AM
hodakaguy's Avatar
Default Rough Idle question at start up
I have a 06 XA with about 5000 miles on it. It sat for about 48hrs and yesterday when I started it up the engine shook pretty good like a cyl was firing rough or something. After 40 seconds or so it cleared up and ran normal. Today I started it up and it did the same thing, a real rough idle the first time it was started and then cleared up again.
I'm going to take it to the local dealer and have it looked at. Any ideas what is causing this?
Thanks in advance!
Hodakaguy
Old May 11, 2007 | 02:16 PM
vintage42's Avatar
Default Re: Rough Idle question at start up
Originally Posted by hodakaguy
I have a 06 XA with about 5000 miles on it. It sat for about 48hrs and yesterday when I started it up the engine shook pretty good like a cyl was firing rough or something. After 40 seconds or so it cleared up and ran normal. Today I started it up and it did the same thing, a real rough idle the first time it was started and then cleared up again...
A cylinder was not firing. One cylinder with a miss makes a 4-cyl engine shake badly and barely run. A cold miss that clears up can be caused by moisture in the ignition, often in the plug connectors or plug recesses. Was it rainy, did you drive through puddles fast, or did you recently wash the engine? If moisture-related, you would expect the ignition to dry out completely after it starts and drives around for awhile.
Since your problem re-occurs, maybe it's not moisture.
If it's a problem in the ignition system itself, I would think the CEL would come on and there would be a trouble code to work with.
Old May 12, 2007 | 12:37 PM
vintage42's Avatar
Originally Posted by Andrew_Stevens
...my car has a rough idle when I start it up. This morning when I started it up I had the rough Idle and for a few seconds it sounded like someone was kicking rocks around iinside my engine.... I'm thinking about chaning my spark plugs and resetting the ECU.
https://www.scionlife.com/forums/vie...535&highlight=
Your problem when starting is not pinging. The noises you heard mean it is not even likely to be ignition-related, and more likely to be mechanical-related. So don't mess with your plugs or ECU.
The brief "rocks in the engine" sound, combined with the roughness, occuring momentarily only on a cold start, probably indicate a valve problem, sticking or whatever. It has happened in two of our vehicles (not xB), where it was transitory; it happened once and then not again. Unless it happens several times, I would not worry.
Unless the dealer can repeat it, and/or see a trouble code, I don't see what he can do about it.
Old May 24, 2007 | 12:59 AM
ICE4ROG's Avatar
I cant answer your question as to "why" your engine does that at startup, but I can give you a tip that will both clear up the rough idle and give you better gas mileage (I cant take credit for this advice, its old news, tried and tested). Go to most any autoparts store and go to the paint section, look for Klean-Strip pure acetone, next time you fill up put 2 ounces of the acetone in the tank first (use a long skinny funnel so the acetone bypasses the charcoal cannister thingy), then fill up.
Are you using 87 octane gas? Sometimes bad gas can cause your engine to idle rough, im no expert...If you want to know more about acetone in gas go to brightgreen.us or to lubedev.com and read about, or let us know if you find out what is causing it and what it took to fix it, thanks.
Old May 24, 2007 | 03:45 PM
vintage42's Avatar
Originally Posted by ICE4ROG
... I can give you a tip that will both clear up the rough idle and give you better gas mileage... look for Klean-Strip pure acetone, next time you fill up put 2 ounces of the acetone in the tank...
Acetone has been "debunked" in one of the SL threads on it.
https://www.scionlife.com/forums/viewtopic.php?t=99679
At least, it is controversial. If 2 ounces of acetone to 10 gallons of gas really, by itself, increased the mileage by 10% or more as some claim, acetone would not remain such a secret or myth.
... Are you using 87 octane gas? Sometimes bad gas can cause your engine to idle rough...
What does "bad gas" have to do with 87 octane ? 87 octane is the only gas recommended in the manual, and Scion Customer Experience emailed that the engine was designed for 87 and there was no point in using any higher octane.
Old May 27, 2007 | 02:30 AM
bB2NER's Avatar
Music City Scions
Thanks in advance!
Hodakaguy
Sounds like something is up with the cold idle circuit. Being that new I would just leave it at the dealer overnight and then let them witness it the next morning and go from there. Good luck and keep us posted with the results please.
Old May 30, 2007 | 06:13 PM
tcm06xb1's Avatar
Same thing happend to me. My Scan Gauge showed that my idle dropped down to -12 then it repaired itself. I have a manual 06 xb with 5k miles and this was the first time it happend. The only thing different that I did compared to other nights was that it was parked at an angle the the left rear (gas cap side) suspension was almost fully extended, I parked on a hill
archael666
Mar 19, 2019 11:52 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
eatcrispycreme2
Jan 30, 2015 03:43 AM
Bakoscion46x
Jan 19, 2015 02:39 AM
cid_mcdp
Jan 5, 2015 02:45 PM
