Check Engine Light
Old May 11, 2007 | 03:01 PM
mikec7713's Avatar
Default Check Engine Light
I have a 06 TC and it's check engine light just came on. Has this happened to anyone else and does anyone know why it would come on?
Mike
Old May 11, 2007 | 03:07 PM
dessilu's Avatar
u sure it isnt the service engine soon light?
Old May 11, 2007 | 03:08 PM
draxcaliber's Avatar
the cel can come on for a number reasons, most common is that the gas cap hasn't been properly closed tightly enough. if your car is stock, it should be 100% covered by your warranty, so just take it in and have them pull the code to see what is wrong.
more commonly you get cel's from aftermarket air intakes, or headers.
Old May 11, 2007 | 03:09 PM
actually, the maitenance required light, yeah, that is on a timer that just blinks when it is time for an oil change.
Old May 11, 2007 | 03:20 PM
mikec7713's Avatar
I wish I could just pop in and have it looked at. I am currently stationed overseas in England. I was hoping it wasn't something serious. I will still take it in to the base garage and see what they find when they plug it. Hope nothing serious. Thanks
Old May 11, 2007 | 06:30 PM
brian's Avatar
how many miles are on it? a lot of ppl confuse the CEL and maint req light.
Old May 12, 2007 | 02:40 AM
tc_girl77's Avatar
My light came on right after I got it and it was a faulty gas cap.
Old May 12, 2007 | 02:03 PM
mikec7713's Avatar
I just reached 5,000 miles.
Old May 12, 2007 | 02:05 PM
mikec7713's Avatar
Faulity gas cap? How did you find that out and how did you fix it?
Old May 12, 2007 | 03:03 PM
brian's Avatar
if you just hit 5k then it's probably your maint req light (which goes on every 5k miles to remind you of oil changes). Try this, stolen from another thread. Make sure your trip meter is on "odo" instead of "trip A" or "B":
Put your ignition on the "on" position, hold in your odometer switch, start your car, keep holding in the swtich, then it will blink off, once it does your set to go. had the same problem but I went to my toyota dealership to show me, it's really easy
Old May 28, 2007 | 04:15 PM
HaenaN7's Avatar
the CEL came on my car today. I'm sure it's the CEL (the one with the pic of engine and word 'check' on it... right?). I did not have anything done to my car recently... it has 11k on it... ahhhhhh.....
Old May 28, 2007 | 05:08 PM
Mid_Life_tC-risis's Avatar
^^Yep that's the CEL.
If your car is otherwise running normally it's nothing to lose sleep over. (If the car runs like crap then you're in limp mode and then you've got something to worry about.)
Just take your car to an autoparts store (I prefer Autozone), or someone you know who has an OBD-II diagnostic code reader. (You could take it to your dealer if they will read the code for free, if not leave. Autozone won't charge you.)
Hook it up to the OBD-II port under the dash, read the code #'s, write it down. Then clear (erase) the code.
Once you know the code you can look it up in the repair manual in the "Tech" section here on ScionLife. Post back up and tell us what you got.
Old May 28, 2007 | 07:49 PM
ScionJim23's Avatar
I agree with everyone here. Try that stuff. If all fails, desolder the dang light. JK. Dont do that.
Old Sep 7, 2007 | 06:08 PM
richardsayzz's Avatar
how do i set up my maint req'd light to 5k
i think mine came on 3k and i can't find it anywhere in the manual
Old Sep 8, 2007 | 03:24 AM
it is a set timer that you can only re-start. it should go off about every 4500 miles to remind you to change the oil.
Old Sep 10, 2007 | 12:54 PM
theslayer's Avatar
yup
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
Bakoscion46x
Jan 19, 2015 02:39 AM
AdmirN
Jan 5, 2015 10:19 PM
