painting my engine cover...
Old May 12, 2007 | 06:55 PM
hansta's Avatar
Default painting my engine cover...
tring to paint my engine cover and wanted some advice on what kind of paint i should use....duplicolor engine enamel's the only one i can use? if i use any other kind/type other than those, is the paint going to burn/peel off because of the heat?? please !! lemme know please!!
Old May 12, 2007 | 08:05 PM
Hyghgynx's Avatar
Definitely get Dupli-Color High Temp Engine Enamel. I've had mine painted for over a year with that enamel and it looks like I just painted it yesterday. Depending on colors, there are probably other paints you could use. Just go to your local auto parts store and check them out.
Here's a pic...
Good luck with your project!
Old May 12, 2007 | 08:07 PM
jaxtcracer's Avatar
+1 for duplicolor engine enamel... great stuff, had it on my engine bay for a while now
Old May 12, 2007 | 08:14 PM
hansta's Avatar
thanks alot guys for your reply but how bout if i want some other color that don't come in engine enamel? can i paint over enamel and clear coat it? what can i do?
Old May 12, 2007 | 08:23 PM
SwtC44's Avatar
I would think that if you use some other kind of paint, and spay over it with clear engine enamel, you should be just fine, I dont think you should have any problems
Old May 22, 2007 | 01:27 AM
stonecoldnimrod's Avatar
do i have to sand the cover, or can i just spray on after cleaning cover?
Old May 22, 2007 | 05:55 AM
SwtC44's Avatar
when i did mine, i just cleaned it with rubbing alcohol and then sprayed away
my06tc
Jun 25, 2015 12:18 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
wesley_t
Dec 18, 2014 06:59 AM
jdtjunior
Jan 16, 2004 06:20 PM
