t3 60-1*UPDATE/PIX PG3*
Old May 12, 2007 | 11:36 PM
Brett's Avatar
Default t3 60-1*UPDATE/PIX PG3*
im getting a t3 60-1 .63 a/r here real soon and wanted to know how well that would work on a fully built 2.4ltr 2az-fe? will be running 18psi w/ equal length mani, and 3" down pipe. did some searching on other forums, but only found built hondas running them. cant really compare cause of the differance in displacement. if any srt4 owners are running this please chime in. would love to know at what rpm 18 psi hits?
Old May 13, 2007 | 12:00 AM
malloynx's Avatar
did you get a BB or non. the 2.4l is a good size 4 cylinder. i got a 60trim coming myself. i'm thinking you'll see full boost around 3700rpms.
Old May 13, 2007 | 12:05 AM
Brett's Avatar
<---baller on a budget. bushing unit.
Old May 13, 2007 | 12:15 AM
malloynx's Avatar
i hear ya, i got a bushing as well. there is nothing wrong with them. i've been running bushing turbos for a long time. had one BB and didn't really notice the difference
Old May 13, 2007 | 12:20 AM
Brett's Avatar
i notice a diffrence....$$$$$
Old May 13, 2007 | 12:27 AM
Dyltone's Avatar
Brett, you're getting worked up over nothing.
Keep in mind, the turbo I have is a bushing as well. I wanted the 35r but the turbo shop talked me out of it.
1. It's only 400-800 rpm difference in peak spool time.
2. The bushing turbo doesn't need the same maintenance as the ball bearing.
3. The bushing turbo only costs 200 - 400 to rebuild vs 800 - 1000 on the ball bearing.
Once you get properly tuned, the only place you'll notice the difference in on a dyno sheet because you'll see the exact RPM where boost comes in. Next time you drive, even a stock tC, watch the tach between 3k and 4k at WOT in 1st gear and tell me that you'd care if your boost was that much faster? Keep in mind that once you shift, your car will not go lower than 4500 RPM's between gears so you'll effectively be at full boost almost instantly in every gear but first.
Old May 13, 2007 | 12:36 AM
Brett's Avatar
oh im not getting worked up over the fact that its non bb. my 16g was non bb and i never had a problem with its performance. (cant say the same for you ). sorry i know that was low. i just wanted to know cause on all these civic dyno sheets, they wern't hitting till like 5500 rpms. i honestly would like to see fullboost hit right at about 4000 so that i can actually get some useable power on the street without having to start from a 3rd gear 40 mph roll.
Old May 13, 2007 | 09:03 PM
Brett's Avatar
bump. anyone else got some info???
Old May 13, 2007 | 10:22 PM
Scott23's Avatar
I have this same size turbo in my tc. It not a BB turbo and I have full boost around 3500 rpms at 10 pounds. If you have a good manifold you should have full boost by 3500 rpms.
Old May 13, 2007 | 10:30 PM
Brett's Avatar
by "in your tc", do you mean your passenger seat, or your engine bay? if its installed, PLEASE PLEASE take some pics for me
Old May 13, 2007 | 10:38 PM
malloynx's Avatar
civic is a poor comparsion. like i said the 2.4l is a good size engine. more liter= less lag
Old May 13, 2007 | 10:39 PM
Scott23's Avatar
No its intalled I drive it everyday. One of these days I will get around to taking pic of it.
Old May 13, 2007 | 10:44 PM
Brett's Avatar
what kind of #'s are you making?? how come you havent updated your thread??
Old May 13, 2007 | 10:53 PM
Scott23's Avatar
I have been busy with work and working on my house so I havn't had time. I don't know what #'s I'am making because my clutch started to slip a week before I was going to goto the dyno. So I didn't go, and now I got some little thing new to put in before I go.
Old May 13, 2007 | 10:56 PM
Brett's Avatar
stock clutch???
"new little thing, eh?"
Old May 13, 2007 | 11:00 PM
Brett's Avatar
where in miami are you? i might have to come check this thing out.
Old May 13, 2007 | 11:01 PM
Scott23's Avatar
stock clutch lasted about 2 weeks, now I have ACT clutch and a LSD. what a diff.
Old May 13, 2007 | 11:11 PM
Scott23's Avatar
Down around Hialeah about an hour from the track. I was just up around you at the sport compact nat. for that scion vip show.
Old May 13, 2007 | 11:14 PM
Brett's Avatar
whatch doin tomorow?
Old May 13, 2007 | 11:17 PM
Scott23's Avatar
Working Sometimes I go to the scion hangout on wed. in miami lakes.
