Fitment question
Old May 14, 2007 | 08:58 AM
Narcolepsy123456's Avatar
Default Fitment question
I know there is a sticky which addresses whether or not wheels will fit, but there is an inherent problem as to what suspension the cars are running with the wheel size/offset.
I need to know if a 17x7 at +35 running a 205-40-17 tire will fit on a tein s-tech drop? only reason i'm asking is b/c according to the fitment calculator it will fit more flush to what i'm looking for, yet when i tried to order, the distributor says that their computer recommends a +42 offset. thanks in advance.
Old May 14, 2007 | 04:43 PM
Subcompact Culture's Avatar
Yes, it will fit. I'd recommend a 205/45/17 to keep your speedometer correct, though.
Old May 14, 2007 | 05:33 PM
thanks, much appreciated.
Old May 21, 2007 | 06:21 AM
bB2NER's Avatar
Music City Scions
Also according to Tire Rack the 205/40/17 is under weight rated for the xB. Food for thought.
Old May 21, 2007 | 07:27 AM
could you post up more info on that? how did you come up with that info, i did a search on the xA and was unable to find the same?
Old May 21, 2007 | 07:32 AM
only reason i'm asking is there are 205-40-17 that are more than capable of matching the load rating of what the oem tire is capable of.
Old May 21, 2007 | 11:21 AM
not sure of the weight or loads for the xB, but the OEM tire for the xA has a max load capacity of 1102 per tire for a total weight capability of 4408. the car itself weighs a bit close to 3700 lbs, wet, which would allow for 700lbs of passengers/load combined. i have seen more than one tire available in that size that is more than capable of handling that exact same load, but have also seen tires in-capable of doing much more than 3600 lbs.
Old May 21, 2007 | 06:59 PM
bB2NER's Avatar
Music City Scions
I only found out about it when I went to order some Kuhmo 711s for my xB in 17 inch and was informed They (Tire Rack) CAN'T sell them to me for this vehicle. I ended up getting 215/45/17's and liked the additional sidewall for the pothole protection.
Old May 21, 2007 | 07:16 PM
ahh, ok, well in the specs page of every tire, it does in fact list the load rating so you can see what you get before you buy. cost isn't really an option, so i'll make sure it is going to be something that has the appropriate load rating.
Old Jul 29, 2007 | 08:58 AM
THE-MACF's Avatar
I hate to jack a thread but my computer proxy doesn't allow me to use the wheel calculators. I have an xB with tein s-techs and I'm going to put 18 x 7.5 with 42 et all the way around. I'm leaning towards 215/40 x 18 for the tire size. Any help would be much appreciated.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
