Metallic rattling noise from flywheel area
Old May 14, 2007 | 07:41 PM
morris7's Avatar
Default Metallic rattling noise from flywheel area
Bought an 05 stick with 15k miles. It started making an intermittent metallic rattling sound from the flywheel area. It goes away if I put the clutch down just a bit. It does it in any gear and meutral. It's directly engine speed dependent. It comes and goes, but seems to be getting worse, and more frequent.
Also, sometimes my starter doesn't engage; I have to rock the car just a bit in gear, then it works. Also intermittent.
Any ideas? Seems like they're related.
Old May 14, 2007 | 07:43 PM
burstaneurysm's Avatar
Is it under warranty by chance? It should be with only 15k...
I'd take it in, unless there's an aftermarket flywheel or something.
Old May 14, 2007 | 07:51 PM
morris7's Avatar
It's stock, under warranty, and I will take it in. But I prefer to know what I'm taking something in for, so I don't get a BS answer.
Wondering if anyone else has experienced this.
Old May 14, 2007 | 08:14 PM
If it's stock, you don't have to worry about a bs answer. The dealer will take care of it.
Old May 15, 2007 | 05:27 PM
JSosa's Avatar
I have the SAME exact problem. If im not mistaken its the throw-out bearing from the clutch. Its really annoying and happens especially when the car is under load. If you happen to take it to the dealer and they tell you what wrong with it, then give me a PM, just to make sure i get the right thing fixed. Im replacing my clutch very soon, so if its that, then i have no problem. But please let me know.
Old May 15, 2007 | 05:41 PM
morris7's Avatar
I have an appointment tomorrow. Will let you know.
Old May 16, 2007 | 03:24 AM
Persocon's Avatar
I have the same problem. i will be watching this thread. I'm currently waiting for mine to get worse so it's making the noise all the time in order to take it to the stealer.
Old May 16, 2007 | 12:38 PM
JSosa's Avatar
im doing the exact same thing. Im waiting for the either the piece to let go and break, or until someone tells me that i have to change a certain part.
Old May 16, 2007 | 10:31 PM
morris7's Avatar
As I thought, it is a bad clutch throw-out bearing. Will be repaired under warranty.
Old May 16, 2007 | 11:13 PM
JSosa's Avatar
sweet... that will be replaced with my Spec Stage 2 as soon as i get it installed. PERFECT!!
Old May 18, 2007 | 04:42 PM
Bubble2Box's Avatar
Wow...odd timing of this post. My car started doing this yesterday when I left work. After a while the noise stopped. It did it again this morning first thing, but stopped before I left Sonic with my breakfast. I just checked with the dealer, and if they replace the clutch and pressure plate + resurface the flywheel, it'll be over $900.00. Think it's time for me to look at getting the TRD clutch and have someone else do the work. I'd come out cheaper and have the better clutch--over 37K miles, so no warranty left.
Old May 19, 2007 | 01:53 AM
ajayaitch's Avatar
Our cars come with a 5yr/60k mile powertrain warranty.
Old May 19, 2007 | 02:36 PM
JSosa's Avatar
In Puerto Rico you get 3 yrs. 36,000 miles or 6yrs, 60,000 if you decide to upgrade.
As for the clutch i decided to pick up a Spec Stage 2 clutch which only cost me $230.00, brand new and shipped. It definately a better idea to change the clutch then pay the $900.00 to keep the existing one.
Old May 25, 2007 | 05:36 PM
morris7's Avatar
They fixed the throw-out bearing, and threw in a new clutch for free! "a one-time courtesy".
I was generally very impressed with the service department. They treated me very well, as well as when I had a Mercedes years ago.
Old May 29, 2007 | 09:12 PM
ricepatty's Avatar
Default Is this under warranty?
Hi guys,
I'm new to the forum and I have a similar problem. This metallic noise that I got appeared and disappeared pretty quickly. After I initially heard it, I stopped the car to check if I had a can stuck to my front-right wheel. Then, I messed with my 1st gear to see if I could hear it again, and naturally I did ( I was driving straight). Next, I turned my wheel to get into my driveway (I had stopped in the middle of my street), and the noise disappeared. Is there any way you guys know of to create this metallic noise again?
My car is at 34k miles and it's still under the basic warranty (3yr/36k). I called up my local scion dealership and asked if they could check the problem out, but I told them that the metallic noise has disappeared. They told me that the clutch is not under warranty, and that if I just brought the car in for them to check it out, it would cost me $100.
Are they trying to take my money? Or is there a trick to ask them to check out the car for free? I dont want to bring my car in, pay $100 for no reason, and find that because there's no noise from the clutch that I can't replace it. Also, can you replace things under warranty even when things aren't broken? Could I ask them to replace certain parts that are under warranty even if they don't need replacement?
Thanks for all the nice info.
Old May 30, 2007 | 04:03 AM
Persocon's Avatar
throw out bearing could be counted as powertrain since it is not really a wear and tear item.
They say the clutch is not covered under warranty is because the actual "clutch plate" is a wear and tear item.
Tell them it's not the clutch plate, it is a powertrain problem. Powertrain warranty is 60,000 miles
Old Jun 5, 2007 | 01:14 AM
typhoonorchid's Avatar
This noise.
Does it sound like your dragging something metal along the ground? I've heard that once about 2 days ago and stopped and couldn't tell what it was. Hasn't re-ocurred yet.
Old Jun 22, 2007 | 02:08 AM
Bubble2Box's Avatar
Most amazingly the noise disappeared.
If the car were dragging something, I didn't see it.
Old Jun 22, 2007 | 02:59 PM
burkins89's Avatar
I have a 2004 that does this all the time, but the thing is that mine is an automatic and the noise only occurs when starting from a standstill.
Raiders757
Apr 14, 2015 10:26 PM
nazblue5807
Apr 11, 2015 12:20 AM
brownSys
Feb 27, 2015 04:20 PM
XDC
Feb 1, 2015 11:56 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
