**CAR WILL NOT START**
Old May 15, 2007 | 05:08 AM
LIVETOROLL's Avatar
Default **CAR WILL NOT START**
Whats up everyone....just wanted to see if any one had some helpfull advise, We just finished tunning my greddy kit and it ran really good on the way home, it made 290 whp at 10 psi and about the same torqu.....the next morning i was leaving to go to a show and i t would not start....long story short it still wont start it keeps fauling out the spark plugs seems to be geting to much fuel....any one know what the problem could be??
Old May 15, 2007 | 05:30 AM
draxcaliber's Avatar
running too rich would be my only guess... might be kinda late to post a question like this, you should bump it again in the morning.
Old May 15, 2007 | 06:57 AM
rodlandscion's Avatar
leaky injector? Injector correction somehow messed up on the emanage? Emanage not working properly? These are some ideas...
Old May 15, 2007 | 07:02 AM
ih8civx's Avatar
engine management problem of some sort it seems.
Old May 15, 2007 | 03:54 PM
jrodTc's Avatar
I had the exact same problem with my emanage. would not start cold. I would have to unplug it, let the car get good and warm, then plug it back in. I sent it back to greddy and am still waiting on word to exactly what the issue is. Try unplugging the emanage.
Old May 15, 2007 | 04:33 PM
DaGreat1's Avatar
it doesnt start at all...or it starts and then stalls?
Old May 15, 2007 | 04:40 PM
LIVETOROLL's Avatar
it will not start at all....it seems like it wants to but just cant do it....i will try to unplug the emanage but i really do not think that is what would be the problem
Old May 15, 2007 | 05:07 PM
05-RS1's Avatar
LOL i got the same problem with my emanage ultimate. turns out i forgot to switch the internal jumpers on the emanage board to 12V ignition output. From the factory, emanage is set only to 5V output. You NEED to switch to 12V.
Old May 15, 2007 | 06:06 PM
malloynx's Avatar
check your power windows
Old May 15, 2007 | 06:45 PM
krdshrk's Avatar
If you keep fouling the plugs, that means there's a rich condition. How were the A/F's from the tune? Also - are you using the Dezod PnP harness with your EMU? If so, you need to switch the JP8 Jumper from 1-2 to 2-3.
Old May 15, 2007 | 08:16 PM
scandalous's Avatar
Scion Driven Girls
The Dezod PnP harness is a godsend. I'd advise anyone to invest the money into getting one instead of splicing computer wires. [scary!]
What size injectors are you running, Frank? And do you have the correction ratio set properly on the EMU?
Old May 15, 2007 | 08:19 PM
scandalous's Avatar
Scion Driven Girls
Oh yeah, and check the jumpers too! I can send you a diagram of what they're suppose to look like if you need that
Old May 19, 2007 | 02:58 AM
LIVETOROLL's Avatar
YA EVERYTHING IS SET THE RIGHT WAY , I AM USING THE SAME EMANAGE FROM MY LAST TURBO SETUP SO THOSE WERE ALREADY SET PLUS THE GUY THAT TUNED IT THIS TIME AROUND DOUBLE CHECKED EVERYTHING
