clutch question???
Old May 15, 2007 | 03:19 PM
symiansix's Avatar
Default clutch question???
Will be running Greddy turbo kit what clutches are you guys running right now. And need some recommendations on were to buy...
Old May 15, 2007 | 04:03 PM
bfurches's Avatar
ok, you have plenty of options..
exedy, comp clutch (i believe there on about a 2 week backorder right now), act, zoom, possibly fidanza (i know they make a flywheel), TRD...
It all depends on exactly what you are looking for, how much power you plan on making, and how many issues you want to deal with.
Just whatever you do, if you get a clutch from a company like act which powdercoats there pressure plates, make sure you take a wire wheel to the mounting holes and ground down the powdercoat, otherwise over time it will be gin to flake off and you will have some loose spots causing rattles and all sorts of other crap.
look around, theres a ton to go by.
Old May 15, 2007 | 05:34 PM
JSosa's Avatar
Spec Stage 2
Old May 29, 2007 | 06:57 AM
itsme's Avatar
Stage 4 clutch kit from Compition Clutch
Old Jun 4, 2007 | 04:40 AM
proctorsilex's Avatar
i have had a clutchmasters stage 3 and a fidanza flywheel for 15k miles. it has been a great combination, but really harsh for the first 1k. search the power forum. i know that i posted a review.
i've had the blitz sc for the last 2k or so. the clutch has been great.
Old Jun 5, 2007 | 07:28 PM
arizonaturbo's Avatar
I am running 5 psi on the Greddy Kit. Haven't slipped once. I will probably not change it out until it does start to slip. I am going with an ACT Sprung Hub 6 Puck with a Heavy Duty Pressure Plate.
Old Jun 20, 2007 | 09:22 PM
Baine's Avatar
spec stage 2+
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
