Can anyone make a detailed instruction for the PAC-SWI
I'm buying, it, ive read post, and seen the pictures, but was wondering out of the box, what excatly i need to do in step by step, any soldering required, and which connections go where...i barley got my D-3 installed, but with a littie guidance, i was golden..thanks again.
-Dan
-Dan
dan... look in the d3 install thread it shows the only 3 wires needed to be used... i asked the same question as you and got the link to pacs site, just follow the instructions, it seems hard but once your done you will say "wow that was stupid easy!"
No Soldering required, I used those T taps.
and I found it easier to put the unit right under the HU incase I ever needed to reprogram it (which I had to do.. TWICE the thing is so stupid ugh.)
And from the D3 install thread, this picture tells it all
I used butt connectors instead of twisting the wires together, but either way works as long as you connect them.
those + the pac install instructions, I'm not quite sure what else you might need?
i hooked it up to kenwood ddx-7019. (ok, actually my friend did it, but it looked ez enuff.) i programmed it on the second try. just be prepared to take a few runs at the programming cuz they are short-timed steps. take too long and u have to start over..... the results are very good. i noticed that the response time on the actual remote (sw) is a lil slow, but livable.
Originally Posted by Phanon_TC
150 ohm resistor..
brown green brown
brown green brown
Originally Posted by Spect2K3
Here is what you do. You carefully put it back in it's box nice and gently. Go to the post office, and return the biggest headache that you would have now avoided.
this thread explains it pretty well though.... https://www.scionlife.com/forums/viewtopic.php?t=97985
i also swapped my dash kit out with the metra one and now the door cover closes again.
Originally Posted by Tcguy85
i just did mine today. maybe you did something wrong, it was super easy.
You really don't need to solder the resistor in. You can just put the resistor in between pin 7 & 8 on the factory harness. You can use electrical tape to hold it in. Had mine in since Dec, no problems at all. It also allows you to change it to a new car if you sell you tC in the future.
mischadoll
Mar 9, 2015 05:48 AM
carid
Jan 30, 2015 02:23 PM
NonStopTuning
Jan 20, 2015 05:20 AM
