Need some help...will these fit?!?!
Old May 17, 2007 | 01:29 PM
spng-bxb's Avatar
Default Need some help...will these fit?!?!
Hey guys im interested in a set of rims for the xb. They are 18x8.5 with 215/35/18 tires. my question is will the 8.5 inch wide rim rub? i dont really want to do any work on the new box. I bought a set of 20's a couple months back and they didnt fit, so i dont want to keep buying wheels that dont fit! lol but if anyone can give me any info on this it would be greatly appreciated!
Dustin
Oh and i have to try n find the offset but they are Dub Bellagio rims if that helps ne one!
Old May 17, 2007 | 07:28 PM
TerribleTed's Avatar
my 18x7.5's are a tight fit. 8.5's will be very tight. Offset will be critical. I have seen where some people have mounted 8.5's so it can be done somehow, but, I certainly would not want tighter clearances than the 7.5's give. I would expect that rolling the rear wheel lips would be needed (or camber added) and would also expect the fronts to rub near full lock.
Old May 17, 2007 | 07:48 PM
trdsparks's Avatar
You'll have to roll the fenders in the rear. Either that or you'll chew up tires. It also depends on you drop. If you're at stock height you're good.
Old May 18, 2007 | 01:11 AM
spng-bxb's Avatar
so at stock height would i have to roll the fender? also, would it rub on full lock turn?
Old May 18, 2007 | 01:20 AM
trdsparks's Avatar
At stock height you should be fine. But it will not look good. It's your call.....
Old May 18, 2007 | 05:47 AM
Really all depends on the offset.
Old May 18, 2007 | 11:52 AM
Spider13's Avatar
It looks like Dubs come in a 45 offset. You should be fine on the front side, and most likely on the back side. But, You may have a slight issue with the rear clearing the swing arm, also may rub at lock. Good new is any problems aught to be pretty easy to fix.
Old May 18, 2007 | 12:59 PM
My 18x7'5s have a 42 offset they only clear the rear arm by less than 2MM at the tires (the 8.5's will stretch the tires a bit perhaps and make a little more space) I would expect that a thin spacer (5MM perhaps) might be needed for a 45MM offset to not contact.
SpaceCaptain
May 11, 2015 06:24 PM
KTamAK187
Apr 15, 2015 10:08 PM
HotLavaDestiny
Apr 10, 2015 05:10 PM
skruff
Apr 6, 2015 06:34 PM
