ichiba Wheel Spacer
Old May 18, 2007 | 01:45 AM
sciontest's Avatar
Default ichiba Wheel Spacer
i got a set of Enkei RZ5 offset 42 with nitto 205/50/16 for my xa RS2.0 i came in to a problem with them as i was putting them on the rear i didnt even try fitting the front. ok i put the rears on with centering rings and snug the lugs. i notice that on the rear trailing arm has a welded rod running all the way across the dummy axle. now if you look at the weld and have the rim on it rubs the sidewall of the 205/50/16 i was wondering if anyone else has had this problem too cause i called the copany to make sure these were a direct bolt on they ensure me that they were and sold many packages with the same offset and tire size package. well now i order 2 sets of ichiba 5mm wheel spacers. the company told me that they will refund me the amount that i spend on them spacers. i never would have thought that i was in for a project with a set of 16's.
this is good info for those of you that have xa and want to put a set of 42 offset and 205/50/16 rubbers
when i get them wheel spacers in and start on this little project i will post some pictures to show you what i mean and a simple tech info on putting longer wheel studs for the spacers
Old May 21, 2007 | 06:08 AM
bB2NER's Avatar
Music City Scions
You didn't mention what the rim width was? If it was 7 inches they should have fit no problem unless they gave you the wrong offset size.
Old May 22, 2007 | 04:13 AM
sciontest's Avatar
yeah it's 16X7 enkei rz5 42 offset. the rims fits with no rub but the problem is the tires 205/50/16 on the rear the inner sidewall rubs the weld. i will take pictures of it when i get them wheel spacers
Old May 29, 2007 | 09:16 PM
sciontest's Avatar
ok i had the chance today to install them ichiba 5mm wheel spacers. this is a simple install it didnt make a big difference but it did clear the weld and i have my wheel tire combo on the ride. now im rollin lol sorry but i don't know how to post pictures if i figure it out i will post some to show you the install
Old May 30, 2007 | 03:47 AM
bB2NER's Avatar
Music City Scions
Do these spacers go between the hub and wheel? If so did you also add longer wheel studs?
terrye
Jan 25, 2015 05:31 AM
CAtC12
Dec 23, 2014 04:44 PM
avus
14
Aug 6, 2004 09:27 PM
scionara
38
Feb 25, 2004 04:52 AM
Hardhitten
Nov 2, 2003 08:29 PM
