View Full Version : CD Holder (oven) light
Sprockett
09-17-2004, 08:33 AM
How do you get the cover off that is covering the lights inside the so-called "easy-bake oven", or the little CD holder with the flip up cover (which ever name you prefer). I see two tabs in there, do I just take 2 flathead screwdrivers and push in on them and torque down, or is there more to it? I don't want to break anything, but I have a few extra red LED bulbs around and I'd like to change the color of that light. I'm guessing it's just a 194...is that right?
mikochu
09-17-2004, 10:48 AM
I haven't been successful in getting to the bulb that way. What I did was take the side accents off (silver pieces). Start from the bottom, wedging them out...then finish taking off the top. After that, the easy bake oven has...I believe 4 screws (maybe 2?). Unscrew them and the oven should come out. at the top, there will be two wires and a bulb socket. Just unscrew the socket and tada...you can get to the bulb!
chewd0g
09-18-2004, 09:17 AM
http://www.scionlife.com/forums/viewtopic.php?t=11283
that may help you get the parts miko is talking about off...
engr
09-20-2004, 04:00 PM
Bro,the side strips should be removed from TOP to Bottom. The sequence is impt from preventing damage.USe something blunt/screw driver wrapped with lotsa black tape.Pry the 2 open and u will see some screws. Just remove the oven box by removing 4 screws. U will see a blub with an orange rubber cap. Replace the blub with whatever colour u desire.Cheers!
Ashe_WCM
09-20-2004, 07:32 PM
I've replaced this bulb, by taking everything out. I'm not sure what number bulb it is but it is a Wedge bulb. I made an adaptor to hook a 6 inch neon up to for mine. thinking of redoing it tho.
