View Full Version : shocks on doors *UPDATED Pics*
TheIcon
09-17-2004, 10:35 AM
Well last nite I continued installing my lambo doors. Needless to say removing the fender was a MAJOR pain in the ___. Anyway I got the hinge attached to teh door and frame of the car. The lambo door hinge uses a shock. This is where my problem is. The shock doesn't move. So the door stays in one spot not going up nor down. I am not sure if there is a trick to making the shock work or if the shocks are just bad. I expected them to work like a screen door on a house. Any comments?
ltj42884
09-17-2004, 12:13 PM
is it in the right place? if something like that isnt located at the correct angle it will not work right
TheIcon
09-17-2004, 12:46 PM
Yea it is definately on propperly. I can't even move the shock when it is off of the car. I can't get it to move up or down at all.
I put all my body weight practically on the shock and it didn't depress down. Im thinking something has to be wrong with it. Actually both of them. :(
TheIcon
09-17-2004, 01:15 PM
Well I just called the guy that sold it to me and he said the weight of the door alone should work the shock. But I told him my case and he said he has never heard of that. So we shall see what happens.
ltj42884
i am assuming that they use air in them...is there a valve to adjust the pressure...try letting some of the pressure out...im just throwin out ideas
TheIcon
09-17-2004, 01:59 PM
Nah any kind of suggestion Im up for. I would hate to have to sent the parts back adn have them ship them to me again cause my car is in like 8000 pieces. lol. It doesn't look like there is a spot to let pressure out but I will check it out when i get home from work.
chucksu
09-17-2004, 03:57 PM
Man that sucks. I think the shocks would be gas charged maybe. Is this kit built for the xB? If so then everything should work :?. If you dont need to pay for shipping again then its all good other then your car being in many pieces.
TheIcon
09-17-2004, 04:40 PM
What do you mean by gas charged?
Yea it is for the XB. My only other prob I may run into is rubbing on my fender which I hope doesn't happen cause that will be a major fix. I wouldn't think i would need tp pay for shipping since they sent me faulty stuff. But I was hopping to have this done this weekend. Looks like my car might be outa commish for a week or so.
chucksu
09-17-2004, 04:48 PM
Im not sure what kind of shocks they are. If they are made like car type they could be filled with any number of things other then just air. I was just saying that, as a reason why there might be no valve to release some pressure from it.
This does not have to do with your topic but it gives 2 examples of shocks. http://www.jcwhitney.com/autoparts/CatalogOrderSearch now again these are for cars as part of the suspension. I would think the design of the shock for the door would be similar, just smaller because it does not need to hold as much weight. Sorry I cant help much.
the_saint
09-18-2004, 03:30 AM
It sounds like the kit uses lift supports/lift cylinders/whatever you want to call them. The same thing that is used on station wagon hatches, pick up toppers, ect. It's a pressurized cylinder and it sounds like you have the wrong ones. Normally when they fail, they lose pressure and don't hold anything up, but yours sounds like the opposite. That is why I think they might have sent you the wrong one. These things are catagorized by length and pressure (how much pressure is inside). Alot ot these things are 50# and up and EXTREMELY difficult to compress w/o any leverage (being installed) so that would be why you couldn't compress it on your own.
Since (I'm assuming) this thing is going to be a show car, why don't you look into linear actuators? They're kinda spendy, but it would be hella cool to push a button and have the door go up on its own. 8)
TheIcon
09-20-2004, 11:53 AM
Well I sent them back to the manufacturer because they said something is obviously wrong. They are going to ship me 2 new shocks. Hopefully be here Thursday and I can see if they work. (yes they are gas filled)
As far as using linear actuators. I want to do this :) For now I believe I am going to use the shocks though because the kit came with these shocks and I have to chill on my money spending for a few months :)
TokyoRaver
09-20-2004, 12:05 PM
Definitely share some pics of your box when you're done with it!!
Did you ever 'glass your roof? I'd love to see pics of that
TheIcon
09-20-2004, 01:51 PM
I haven't glassed my roof yet. I was actually thinking of doing that now since I have about 4 days before the shocks come in the mail. Since my car is already in 80982430592 pieces mide as well take the roof off to :)
TheIcon
09-24-2004, 10:47 AM
Ok and update.
l I got my 2 new shocks in teh mail today. The one works after tugging on it a bit. The other one is doing the same thing the previous 2 were where it is stuck in one spot. I don't know if it will start working after I work at it a bit or not. (Like it is stuck and just needs to get moving to loosen up)
Anyway I noticed someone in another post said they would give more credit to someone that put suicide doors on there car rather than lambo doors. Because lambo doors you can just bolt on with a kit. Well whoever said this OBVIOUSLY hasn't ever tried putting lambo doors on there XB. THIS IS NO EASY TASK. :x I have spent 10 hours so far. And only have one door on and it is not even finished completely.
As far as problems. What I am running into now is that the door is not flush. The front of the door sticks out about 1/4 of an inch. So when I put my fender back on it will be slightly noticable. I believe it can't sit flush because the hinge is obviously different. Also I am not sure if this will truely be noticeable to the common person or not. My g/f didn't even notice. Im not sure if there is a correction for this issue.
TokyoRaver
09-24-2004, 10:50 AM
Does it still have a seal? If you're not getting wet when it rains, I don't think it would be that much of a problem.... you got any pics?
TheIcon
09-24-2004, 10:59 AM
The seal is good. That was part of a discussion I had with a friend. It functions properly. But to anyone with a trained eye they will see that it is slightly off. To me its not a huge deal.
I should have some pictures by Saturday. Camera is recharging as we speak. :)
FuglyxB
10-04-2004, 07:02 PM
Must be a slow charger... or a REALLY long reach!
WHICH Saturday did you mean?
TheIcon
10-04-2004, 07:33 PM
smart ___...LOL Im sorry. I haven't posted them yet. I got the pictures just haven't uploaded them.
TheIcon
10-05-2004, 11:07 PM
Here are some updated pics. Hopefully this link works
http://www.imagestation.com/album/?id=3246530093&congratulation_page=Y
the_saint
10-05-2004, 11:40 PM
Sweet 8) Good job man. I'm glad to see you're making progress. Hopefully you won't hit anymore snags. :evil:
Do you have any pics from the backside with the door open? So we can see how far out the door swings.
TheIcon
10-06-2004, 12:00 PM
Ill get some pictures from the backside. I didn't even think to take a pic there. I might stand next to it so you get an idea of how wide it is.
TCLunchBox
10-06-2004, 12:19 PM
Where did you get your kit from? I was thinking of doiong the same thing.
DJ_X_Trodinaire
10-06-2004, 01:24 PM
good job but i hope thats not duct tape youre using! :shock:
and we will see you at the BBQ in two weeks?
Munch
10-06-2004, 01:25 PM
Sweet 8) Hope the kit works out for you. Looks like more work than I would like to deal with for the doors, but that's just me :lol:
Munch
Looks like duct tape to me. It's gonna be a pain in the a$$ getting the residue off the paint once he removes it :(
TheIcon
10-06-2004, 01:37 PM
Its duct tape. i have removed it like 20 times already. Its not hard and there is actually very little residue surprisingly which just rubs off when I take my finger over it.
TheIcon
10-06-2004, 02:01 PM
I got them from RedRumCustoms
hotbox05
10-07-2004, 12:07 AM
ok with the 1/4 inch thing . i would say try slightly bending the lambo hing inward i'm pretty sure it should do the trich. by bend i mean lightly tapping with sledge untill fitment is correct. it really isnt that barbaric.. i'm still waiting for a suicide rear door kit.
TheIcon
10-07-2004, 12:01 PM
Actually if you use the one pic I have of the lambo hinge. If you either shimmy the right side of it out or if you bolt down the left side the door will go flush. For whatever reason in my head it does the opposite of what I think it would.
Yea I would love suicide doors on the back but I think I am taking a break after this project. I don't wanna touch a door for awhile :D
