2008-2010 [ZSP110]
xD with not so good review 27/33 mpg??????
Old May 19, 2007 | 03:47 AM
SHU's Avatar
SHU
Default xD with not so good review 27/33 mpg??????
Maybe some of you dealers can clear up this mpg they mention.
Say it ain't so.
New xB, xD Improve Scion Breed
By Christie Schweinsberg
WardsAuto.com, May 1, 2007 11:52 AM
HOLLYWOOD – When Toyota Motor Corp. first decided to create a youth-focused brand for the U.S., it seeded the new marque with two Japan-market models, the Ist and bB, rebadged as the Scion xA and xB, respectively.
The move served a couple of purposes: It kept development costs low, and it tapped into the fascination some U.S. youth have with Japanese culture.
ADVERTISEMENT
While the jury remains divided on the xA hatcback, the success of the rectangular xB ute and later-launched tC sport coupe have driven sales above projections, silencing the naysayers who believed Toyota had made a mistake with the narrowly focused Scion brand.
Now, three years after its national rollout, Scion is ready with a redesigned xB and an all-new replacement for the xA subcompact, dubbed the xD. Unlike its predecessor, the new xB rides on a separate, larger platform from the bB, itself redesigned for Japan last year. And the xD shares its underpinnings with the larger Toyota Yaris’ chassis, not the Ist.
The xB’s wheelbase, at 102.4 ins. (260 cm), has been increased 4 ins. (10 cm) from that of the outgoing model. Length is up a substantial 12 ins. (30 cm) to 167.3 ins. (425 cm), while the front and rear tracks have grown 2.7 ins. (7 cm) and 3.5 ins. (9 cm), respectively.
xB rides on all-new platform, similar to that underpinning Toyota’s European Auris.
This boost in area helps plant the xB more firmly on the twisties here in the Los Angeles-area, although the vehicle’s square shape puts it at odds with such an excursion. Really, the xB feels most at home cruising city streets, where it blends in well with the oddballs on Hollywood Blvd.
A McPherson strut front suspension keeps the ride compliant, while the electric power steering lacks the overly light feel that’s characteristic of many other Toyotas.
The electric power steering is said to increase fuel economy 3%, though, a gain likely needed to compensate for the installation of the larger, 2.4L 4-cyl. engine under the new xB’s hood. Replacing the wimpy 1.5L of the outgoing model, the new four-banger cranks out 158 hp, up from 103 hp for the outgoing model, making for comparatively blistering acceleration.
’08 Scion xB Vehicle type Front-engine, front-wheel-drive 4-door car
Engine 2.4L (2,362 cc) DOHC inline 4-cyl. aluminum block/aluminum head
Power (SAE net) 158 hp @ 6,000 rpm
Torque 162 lb.-ft. @ 4,000 rpm
Compression ratio 9.8:1
Bore x stroke (mm) 88 x 96
Transmission 5-speed manual; 4-speed automatic
Wheelbase 102. 4 ins. (260 cm)
Overall length 167.3 ins. (425 cm)
Overall width 69.3 ins. (176 cm)
Overall height 64.7 ins. (164 cm)
Curb weight 3,020 lbs./1,370 kg (manual); 3,086 lbs./1,400 kg (automatic)
EPA fuel economy, city/highway (mpg) 22/28 (10.7/8.4 L/100 km)
Market competition Chrysler PT Cruiser, Chevy HHR
Although still relatively small by U.S. standards, the engine, also available in the tC and Toyota Camry, is a real treat, often more enjoyable than even the Camry’s V-6.
In the new xB, the engine is mated to either a 5-speed manual or 4-speed automatic transmission, the latter of which proves competent. Despite the gathering industry movement to 5-speed automatics, Scion officials say their customers aren’t pushing for the extra gear. Cost also factored into the decision to stick with a 4-speed.
The xB’s interior is well done, despite the liberal use of hard plastic. One minor complaint on both the xB and xD is the rough-to-the-touch rat-fur headliner. Even the cheapest vehicles from Korea have moved to more appealing knit material. Pre-production models driven here also suffered from some fabric puckering.
The xD, meanwhile, is an oddity. Replacing the low-volume xA, it has grown some in size, matching up more closely to the old xB, with a 96.9-in. (246-cm) wheelbase.
It also shares the xB’s boxy lines.
Making its North American debut is Toyota’s 1.8L inline 4-cyl. engine, up to now available in the Yaris TS in Europe and the Corolla in Asia.
The mill makes 128 hp and 125 lb.-ft. (169 Nm) of torque, vs. the paltry 103 hp and 101 lb.-ft. (137 Nm) of the xA’s 1.5L.
xD sized between old xA and xB.
The power boost is welcome, but it’s not enough to eliminate the occasional white-knuckle moment, as when the xD, throttle wide open, hesitates during a merge onto a crowded L.A. freeway.
Both the xB and xD engines get Toyota’s dual variable valve timing with intelligence (VVT-I), marking the technology’s first use in a compact mill (it was introduced on the Avalon’s 3.5L V-6 and also is available on the Tundra’s 5.7L V-.
Like the xB, the xD also has a McPherson strut front suspension to keep its ride agreeable.
Related Stories
Scion Expects xB Sales to Hold Line
The car carves up the curves a bit better than the xB, thanks to its more compact dimensions and lower center of gravity, but it won’t be confused with a BMW 3-Series.
The xD’s interior is a standard charcoal gray. Scion wisely located the gauges in their rightful place: behind the steering wheel, not atop the center stack as in the xA.
A cool single concentric combination meter integrates the speedometer and tachometer functions. Scion officials are mum on whether other Toyota models will get this, but it appears to be a safe bet the xD won’t mark the only application, as the combo-gauge frees up design space for more interior creativity.
’08 Scion xD Vehicle type Front-engine, front-wheel-drive, 5-door hatchback
Engine 1.8L DOHC 4-cyl. aluminum block/aluminum head
Power (SAE net) 128 hp @ 6,000 rpm
Torque 125 lb.-ft. (169 Nm) @ 4,400 rpm
Compression ratio 10.0:1
Bore x stroke (mm) 81 x 88
Wheelbase 96.9 ins. (246 cm)
Overall length 154.7 ins. (393 cm)
Overall width 67.9 ins. (172 cm)
Overall height 60.0 ins. (152 cm)
Curb weight 2,625 lbs./1,191 kg (manual); 2,665 lbs/1,209 kg (automatic)
EPA fuel economy, city/highway (mpg) 27/33 (8.7/7.1L/100 km)
Market competition Toyota Yaris, Honda Fit, Nissan Versa, Kia Rio, Chevy Aveo
The xD is roomy, and front seats are comfortable on long drives. But rear seats in both the xD and xB lack padding and are quite uncomfortable and not made for extended journeys.
Fuel economy for both models is down significantly from their predecessors, thanks to their ’08 model status (that makes them subject to new, less favorable mileage calculations), larger engines and increased heft. The manual xD gets 27/33 mpg (8.7-7.1L/100 km) city/highway vs. the 32/37 mpg (7.4-6.4 L/100 km) for the ’06 xA.
The xB is rated at 22/28 mpg (10.7-8.4 L/100 km) with either the automatic or manual, vs. 30/33 mpg (7.8-7.1 L/100 km) for the ’06 manual model.
With such standard features as vehicle stability control, tire pressure monitoring, 4-wheel disc brakes and steering wheel-mounted audio controls, the ’08 xB is a good value starting at $15,650, despite its steep, 11.5% price hike from the outgoing model. Automatic-equipped xBs begin at $16,660, up 11.9%. Destination and handling adds $580.
The question is whether xB loyalists will flock to this box the same way they did to the original, smaller xB. With the redesign, the xB has lost some of its quirkiness. Sharp creases have been abandoned in favor of more rounded edges and the front fascia has been revised and now features a more conventional grille placement.
The xD, which will see pricing released closer to its August launch, features an xB-like body with a Yaris face. Subcompacts in the U.S., in general, lack allure, but this one is particularly unappealing. The greenhouse is out of proportion to the bulk of the body below the beltline, and the space between the C and D pillars makes the xD look as though it originally was designed as a sedan.
Even if it doesn’t appeal to targeted urban hipsters, the new xB, thanks to its larger engine and dimensions, should continue to intrigue Baby Boomers, who flocked to the first-generation model for its ample interior space and easy ingress and egress.
But the xD may be more likely get stuck in the penalty box of the U.S. new-vehicle market.
Old May 19, 2007 | 08:06 PM
scionofPCFL's Avatar
Congratulations on being rescued! It seems all of this is new to you, so the natural assumption is that you've been lost on a desserted island somewhere....Ok, I kid, but it's been hashed out here on a 1/2 dozen or so threads for the past 3 mos, but I'll go ahead and let you in on it anyway.
The EPA has redone their tests to reflect more real world driving. They are ditching the 30 year old conveyor belt tests and actually driving the vehicles in real world conditions in a realisitic manner. Because of this everybody's fuel milage will be going down for all 2008 models. The xB and xD are simply the first 08's available anywhere, and people aren't yet accustomed to them.
If you goto the epa's website (epa.gov I think) they have all of the information there, and they have convertor to sort of gauge how the old numbers will convert to the new ones. When you do that and compare it to the xA, you'll see that the milage actually goes up a bit. Which is pretty remarkable considering bigger motor, more power, and larger car.
Old May 22, 2007 | 04:42 AM
eggie's Avatar
Pssshhh, O get 27 now in my box with less power. I'd welcome the 1.8 and probably get more mpg
Old May 25, 2007 | 08:52 PM
mabforlife's Avatar
I like the idea of the Dual VVTi. It is about time in toyotas world to finally apply better technology to somewhat "lower end" vehicles as compared to other vehicles on the market. I just still wonder with all this gas craziness, and these cars are generated for "Gen-Y", wouldn't it be Toyota's best interest to appeal to a better gas efficient market? I do not think that the xB with only being 22 city and $16,000 (about a $1600 inccrease from previous xB) will actually strike buyers into buying this kind of vehicle. It kind of reminds me of the Element- 2.4 160 hp, same kind of box shape, better gas mileage also- but even with the xD suppose to be on the same platform as the 08' corollas... what is going on toyota?
Old May 27, 2007 | 03:48 AM
dmpsk8's Avatar
for the record, I love the dash top gauges of the xa and xb. looks foreign, unique, and downright sexy
hampton1100
May 28, 2015 07:32 AM
Renike
May 10, 2015 02:10 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
scsteven
Jan 25, 2015 01:06 AM
scionboxrox
Nov 24, 2014 06:38 PM
