PLEASE explain D3 mounting bracket(kinda urgent)
Old May 19, 2007 | 07:20 AM
blazeplacid's Avatar
Default PLEASE explain D3 mounting bracket(kinda urgent)
ok I have installed my D3 wih great pride.
only thing is of course the door doesnt close.
can someone explain the "drill 3/16"" part??
Im good with tools I just dont understand that for some reason.
Do I drill "back" 3/16 or do I make the hole larger???
someone please explain,im going on a road trip and staying in a hotel and dont want any problems
anyone got any pics of a before and after or something,I dont know why but it has me confused......maybe cuz its 2:30am??
Old May 19, 2007 | 07:22 AM
SquallLHeart's Avatar
drill back... so it is mounted back a little more.
Old May 19, 2007 | 07:26 AM
Phanon_TC's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=165675
6th picture down... shows u how it should look after I drilled mine with 3/16' drill bit
drill where their are small indents and use those to mount the d3 instead of original holes so the door closes flush
Old May 19, 2007 | 07:55 AM
so where the "dots" are on the inside drill through them??
is that correct?
that makes sense.
Old May 19, 2007 | 07:57 AM
Phanon_TC's Avatar
yes.. use those indents or dots and drill with the 3/16 drill bit
or just compare the unmodified brackets with my picture and you will see what i mean by indents
Old May 19, 2007 | 08:01 AM
yeah im kinda sleepy but I get what your saying,thanks for help,I will get this done when i get up
thanks agian
Old May 19, 2007 | 02:44 PM
Diversion's Avatar
I still haven't done this mod so that my door closes either..
So did you not want to put in the 3rd bolt for a reason or did you put it in there at a later time, Phanon? (Referencing the 7th picture down).
Old May 19, 2007 | 04:34 PM
ADRdesignCo's Avatar
if you are talking about the one with the harness, it looks like there isnt a hole for it (the third one), or its covered by the metal. and if its just the harnes youd only need 2 on each side (its mainly food looks doing this kinda set up, since the metal harness is your main one. there looks to be still three screws that actually hold the deck in the metal bracket. at least from the looks of it.
Old May 19, 2007 | 05:53 PM
Phanon_TC's Avatar
didnt think of it at the time i was installed it and skipped it. was too focused on the metra kit. i have yet to put on that 3rd screw. works fine with just those 2 screws.
Old May 19, 2007 | 09:09 PM
satoman44's Avatar
why don't you guys take a dremel to the back of the radio and "gut" out where the volume **** is. I did that and my radio door closes perfectly without having to recess the unit in more.
Old May 19, 2007 | 09:28 PM
Phanon_TC's Avatar
lots of ppl dont have dremels and could be a disaster if you do dremel and mess up.
drilling into brackets is much easier and cleaner also imo
Old May 19, 2007 | 11:25 PM
^x2
Old May 20, 2007 | 01:32 AM
satoman44's Avatar
lol, i think you have to try to mess up. its not that hard, you see where the **** hits, and dremel away. as far as being easier and cleaner? i did it my way cuz at first i tried to drill, but i didn't have a bit for drilling into metal. so the dremel was easier in that sense. as far as clean, you can't see it at all, it is behind the door after all.
but ya, i guess if you don't have a dremel, then my way is hard. just throwing out another option out there.
Old May 20, 2007 | 08:52 PM
Diversion's Avatar
Having the headunit recessed by drilling in the brackets is probably the easiest method.. and since it recesses the radio in the dash a little further, it keeps the sun from glaring on it as much as before ;)
Jay
Old May 20, 2007 | 11:01 PM
i actually know a guy that messed up. he accidentally dremmeled the wrong side of the door (still the black side, just not the side where the little knub was. lol) no names. hahahhaa ;)
Old May 20, 2007 | 11:23 PM
chinito's Avatar
hey i drilled where that picture (6th down) shows. IT WORKED GREAT! course i have the kenwood ddx-7019, but the door closes with the radio off and with the screen in the inverted angle and the first angle-out (u know when the screen has the bottom part angled out...) if u adjust the scrren angle any more, the door wont close i think. of course with our sunroof the inverted angle works best anyways. thanks again for the great diy help.
yhwhdesign
Jun 11, 2021 03:34 PM
Exokutioner
10
Jan 26, 2009 08:37 PM
TheDave1022
Scion tC 1G ICE & Interior
177
Sep 28, 2008 06:31 AM
Spr0ket
Jan 30, 2006 03:54 PM
riccochetrabbit
15
Jul 21, 2005 01:49 AM
