dizzytc
09-17-2004, 08:30 PM
Will this work? The tires I have are 215/60R16 on steel rims. I need new tires...so figure see if I can get the tC stock rims...but will they fit?
View Full Version : tc Stock wheels on 2003 Camry SE dizzytc 09-17-2004, 08:30 PM Will this work? The tires I have are 215/60R16 on steel rims. I need new tires...so figure see if I can get the tC stock rims...but will they fit? chucksu 09-18-2004, 01:13 AM So let me get this right. You want to put tC wheels onto a Camry? Camry bolt pattern = 5x114 tC bolt pattern = 5x100 So nope. Hope this is the question you where asking & the straight answer to. dizzytc 09-18-2004, 01:52 AM what about the 18" EMX Super 7? ShadyEye16 09-18-2004, 02:18 AM The lug pattern is the pattern that the car's lug bolts are in (in the tC's case, 5x100 means 5 lugs, with 100 mm between the centers of each opposing lug) Basically, the 18's are also made for the tC so they won't work on the camry either chucksu 09-18-2004, 03:06 AM In the most simple answer. Almost any wheel that fits the tC will not fit a Camry. IIRC the Lexus IS300 uses the 5x114 bolt pattern so might want to look at some of those wheels. Just took a look & yes they share the same pattern. So only need to worry about back spacing. |
