HIDs not working :/
Old May 20, 2007 | 06:30 AM
Ankryth's Avatar
Default HIDs not working :/
So I put in some 10000k hid's in my Tc today and they worked where I installed them and driving all the way back to my house, but 2 hours later when I came out to my car to show my friend the new lights...they just flickered on and then stayed off. Anytime i go to turn on the headlights all they do is flicker on for less than a second and stay off.
How can I fix this problem?
Old May 20, 2007 | 06:31 AM
Neothin's Avatar
connections good? power harness/switch/ballast/bulb connections...
Old May 20, 2007 | 06:32 AM
rockbrawler884's Avatar
recheck all your connections
Old May 20, 2007 | 06:33 AM
Neothin's Avatar
yeah...... sounds like something came loose on the drive home
Mightygnu's Avatar
thats about all you can do, where do you buy these HID's?
Old May 20, 2007 | 06:43 AM
Ankryth's Avatar
i just went out and kinda checked my connections (its a little hard to do at night lol) they all appear to be fine. I would think though if it were a connection issue that one HID would be working and the other wouldn't...it seems strange that both are having the same symptom
Old May 20, 2007 | 06:44 AM
Neothin's Avatar
which is why i think your main wiring harness has a problem somewhere.... that would affect both lights...
Old May 20, 2007 | 06:50 AM
pinoy_TSX's Avatar
Default Re: HIDs not working :/
HAHA! maybe your HID's are not designed for showing off.
Old May 20, 2007 | 07:05 AM
Ankryth's Avatar
ok if you think its my main harness then what more specifically do you think could be the problem? My other friend said that it could be the fuses and they should be upgraded to 30mA but the fuses aren't blown so it couldn't be that...
Old May 20, 2007 | 07:07 AM
Neothin's Avatar
are the connections on the battery secure? are the connections going into and out of the fuse holder on the harness secure? is the connection for remote turn on for the relay secure? the plugs that are for your original bulbs...a re they dirty?
i mean, shoot. they worked... it's not like they're broken
Old May 20, 2007 | 07:29 AM
Ankryth's Avatar
for this kit you don't attatch it straight to the batter...you stick little metal prongs into the former light socket and electric tape it up. That way the existing headlight switch will still turn on the headlights.
Are you saying that me installing a relay for that could solve the problem? I don't see how it could since the damn things worked b4. This is really frustrating :/
Old May 20, 2007 | 07:44 AM
Neothin's Avatar
you have to stick little metal prongs into the stock sockets? and you pull *all* that power through the stock wiring? ummm... HID's on startup pull *alot* of power, and i dont think little metal tidbits shoved into a connector are all that great :-/ let alone pulling that much power through iddy biddy wires.
i'd check on the prongs...
Old May 20, 2007 | 09:11 PM
Ankryth's Avatar
ok so its not the connection cause i cut off those stupid metal prongs and straight sodered them to the headlight wires behind the socket. They h ave power and ground going into the ballest but the ballest are sending two grounds to the bulb...what could that be a sign of?
Old May 20, 2007 | 09:26 PM
Ankryth's Avatar
The brand of the HID's are Xentec
Do you guys think i may need to wire up a relay to give them more amps?
Old May 20, 2007 | 09:29 PM
burninskulls0911's Avatar
check your ground and make sure its making a good connection with no paint between the connection
Old May 20, 2007 | 11:19 PM
Ankryth's Avatar
i sodered them to the factory low beam wires so the ground is as it should be
Old May 21, 2007 | 09:03 PM
Ankryth's Avatar
does anyone have the wireing diagram for the headlight system? My mechanic thinks it may be a resistor or relay issue and i need to know which ones are connected to the headlight system
Old May 22, 2007 | 07:34 AM
pinoy_TSX's Avatar
Why don't you test your HID's with another car and see if it is working.
Old May 22, 2007 | 12:42 PM
timmyinpajamas's Avatar
DeepSouth Scions
i dont think hookin up power wire 2 ur existing wiring harness is strong enough .. wat kinda hid kit does that .. u gota hook dat bad boy up 2 da battery dawg .. its all about dem batteries homie g funk da crunk
Old May 22, 2007 | 08:12 PM
raWr215's Avatar
connection is everything when it comes to electrical stuff.
If you installed the kit correctly and the connections are good, then the kit sucks!
