Do I have everything for an Install?
Old May 26, 2007 | 06:41 AM
SoCalMixedGuy's Avatar
Default Do I have everything for an Install?
Alpine CDA-9883 Face
Alpine MRP-F450 Amp
Alpine SPR-17s Components
Alpine SPR 17c 6.5"s
EFX 8 Guage Amp Kit
Toyota Wiring Harness.
Will I need to do anything custom to fit the 6.5s in the back. Will these tweeters fit in the front without custom cutting? Do I have to run new speaker wire too, or can I just use the stock ones? Im planning to do this on Sunday, so I hope I have everything. Thanks for the help guys!
Old May 26, 2007 | 07:41 AM
LiquidTension's Avatar
the only thing i can be sure about at the moment...i apologize, i just worked a 12 hour shift and then another4 hours with uncle Light and Select and the coworkers ;) ....
you might need a dash kit for the head unit to fill the gap
you can use the same speaker wire, but i think you'll get more out of the speakers if you run better wire
Old May 26, 2007 | 08:06 AM
2_tC's Avatar
You'll most likely need adaptor brackets for the speakers front and rear as the stock ones are a complete assembly with the speaker.
The front speakers are riveted in, so you'll need to drill out the center of the rivets to get it out. The rears are simple 10mm bolts.
Speaker brackets like these:
http://www.crutchfield.com/S-uEKAP0Z...3200&I=142SAT6
Or you can make your own out of MDF.
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
