small squeck coming form crank pulley?
Old May 27, 2007 | 07:34 PM
lowandslow2's Avatar
Default small squeck coming form crank pulley?
I hear a slight squeck like a belt is loose or somthin just when i start to take off but then it stops,it doesnt apear to hurting nething just anoying! I thought it was my ur pulley. the belts are tight and there is now clearence problems with the pulley. ne help would be good.
Old May 27, 2007 | 09:54 PM
jct's Avatar
jct
get some belt dressing to spray on the belts, you should be good to go for a while!
Old May 28, 2007 | 12:28 AM
will a bar of soap work?
Old May 28, 2007 | 12:40 AM
vintage42's Avatar
Spray dressing is OK for simple fan belts spanning between pulleys a good distance apart on the front of an old engine. But so little of the xB serpentine belt is free and clear that spray dressing will get all over the engine.
I would get the kind in a tube, put some on a finger, and apply it to the belt that you can reach. That little bit will get spread all over the belt within a few moments of running, and should do the job.
Belt dressing is a tacky substance that makes the belt grip better, while the soap you propose would be a lubricant that would make the belt slip. Soap would probably change the squeaking, but maybe for the worse.
Old May 28, 2007 | 02:33 AM
jct's Avatar
jct
i've done the soap bar trick and it works, you can do WD-40 on the belts too which does not make the belts slipperier
Old May 28, 2007 | 01:29 PM
thanks.
Old May 28, 2007 | 09:35 PM
vintage42's Avatar
After the soap or the WD-40 stop the squeaking, how long will that last, and what might the long term effect of these compounds on the belt? My experience many years ago with bar soap and WD-40 was not good.
AxRxP
Jan 30, 2015 10:08 PM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
randode
10
Dec 11, 2003 06:05 PM
