Amp/Stereo Question
Old May 31, 2007 | 10:06 PM
SoCalMixedGuy's Avatar
Default Amp/Stereo Question
Do I need a wire harness If Im using an amp? Dont the speakers run into the amp and then the amp to the face via RCA?
Old May 31, 2007 | 10:24 PM
Daskid's Avatar
Well, actually, if you're using the stock radio, you need a converter to wire the amp to the radio using an RCA cable.
If you're using an aftermarket radio, you can buy a wire harness so that you'll be able to install the aftermarket radio with ease. Then just directly wire the amp to the radio with an RCA cable.
Old Jun 1, 2007 | 12:02 AM
jlsmobilesound's Avatar
yes, Jehoo is right - you need a line-out converter to convert your high-output from your stereo to low-output for your amps. However, some amps do come with the wire harness you can plug into that amp and just run the speaker wires to there. The first one is much easier. So it's not necessarily a wire harness but it's called a line-out converter. And just get an amp kit - depending how much power will determine the gauge of wire you need.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
