How Does the MPG Calculator Work?
As we all know, to accurately calculate MPG you need to know two things precisely:
1. The distance traveled, and
2. The amount of fuel consumed.
How does the xB2's computer know how much gas you're using? Can you input the number of gallons when you fill up? Is it somehow measuring the exact amount of fuel in the tank, or monitoring the fuel flow as you drive?
I guess what I want to know is, is it accurate, and how do we know it's accurate?
r
r
It has to be monitoring the fuel used as it uses it. The xB1's computer calculates this as well, you just have to attach a gauge for it to tell you. I use the ScanGauge 2.
It could be monitoring the the rate of fuel going through a given point somewhere in the fuel delivery system for the instant mpg, and then keeping tabs on that in some predetermined incriment to calculate an average.
The only thing the xB1 "knows" about fuel state is when the low-fuel sensor trips.
Obviously, in the xB2 you don't need to tell it the fuel capacity; that would be hard-coded since the computer is specific to the car. My question is whether it, like the ScanGauge, uses derived numbers to calculate MPG (derived from you supplying the amount of fuel you put in at the pump), or whether it has some way of actually measuring fuel flow (which would be something unusual and worthy of note).
r
r
r
You don't have to input anything. It calculates it on the fly and can be reset manually (it also resets automatically when you fill up.
I am an automotive engineer, and if I had to guess, I would say it probably uses the duty cycle information from the fuel injection (how long the fuel injectors are firing), combined with the known fuel injector flow rate, and the vehicle speed.
That way it would know exactly how much fuel is going into the motor and can average fuel use over time and distance. It probably does this constantly, but it updates the display every 10 seconds or so.
Like I said, I don't work for Toyota or anything, so I am just guessing.
You can increase the refresh rate on them. No need to wait ten seconds. I have mine set to 'fast' which refreshes about every half second or so.
r
They could measure resistance somewhere in the system, I'm not a tech so I don't know.
yet they do that anyway already.
the systems basically look at the injectors duty cycle (how many times its opening and closing, letting in fuel), current speed and engine load (strain put on engine). the more load (ex: hills, wind, towing a 10 ton boat behind the xB) will cause the engine to work harder to maintain the same speed. more fuel is needed dropping mpg.
anyways, its not a totally accurate gauge since to max it out all you have to do is take your foot off the gas and it spikes to 99mpg
what I ment by resistance was electrical resistance. There are so many electrical components on a car, that it doesn't seem a stretch to me to have a one or two be effected by gas milage somewhere. Not sure. My first answer seemed to be more logical.
Either way, it doesn't really matter, it does it some how or another and it's most likely a basic off the shelf system used on a hundred different vehicles.
The average MPG and instantaneous MPG would be powered off the same logic unit ( a discrete module) and actually, the avg would just be a summary of the instant.
Nope, don't work for Toyota either, just designed computer hardware for over 30 years here.
-Mick, EE
Originally Posted by linav8
As you scroll through the options it's the first that says a number with MPG in the corner, right?
For the first three tankfuls, I have averaged 30 mpg. But, the xB's calculation shows 2-3 mpg better. This is for a 5 speed in a mix of expressway (55-65 mph) and small town country back roads.
Checked the car last nite to see what the display actually says for average MPG.
To see the Average MPG you are getting, toggle until you get "AVG" in upper left hand of display and "MPG" in lower right hand side.
The instant MPG seems to be all over the place when driving and am not sure what use it really is, except you could find the speed at which you were getting the best MPG when using the cruise control on a trip. Outside of that, not sure what else its for.
