Steelies paint wearing off? And a few other questions...
Old Jun 3, 2007 | 01:17 AM
DiStUrBeD_AzN's Avatar
Unique Scionikz
Default Steelies paint wearing off? And a few other questions...
Does this normall happen? I just kinda rubbed it off after I applied some Tire / Wheel Cleaner/Shine.
I'm worried it was the Cleaner/Shine that "burned" it off. Could that be the factor? It was some cheapo Dollar Store stuff. >_<
Btw, what spray paint should I use for the Steelies? And what size lug nutz do I need for the xB?
Old Jun 3, 2007 | 01:27 AM
TerribleTed's Avatar
Any high quality spray paint would work. Plasticoat has a line of paints specifically for wheels in rattle cans. You want the best ?? remove the tires and take the wheels to a reputable powdercoater
Old Jun 3, 2007 | 03:05 AM
Unique Scionikz
Heh, removing the wheels and powder coating it would cost more than they are work.
Plasticoat? Is that the brand? Does Pep Boys have them?
Btw, can you guide me to buying lug nuts? I see some on ebay, these specifically...
http://cgi.ebay.com/ebaymotors/MUTEK...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Tuner...26484861QQrdZ1
I assume both will fit, but why is the first one so cheap with so many lug nuts? I am using these to complement my rim trims...
Old Jun 3, 2007 | 04:06 PM
streetlethalxb's Avatar
Plasti-coat is at any hardware/auto store.. works great, and
the paint wear there is normal, not the tire shine doing it or
anything else. Scuff them all up with some 360 grit or higher
sandpaper (after cleaning them completely), and spray away.
light even coats, I like plasticoat, bumper black or flat black.
Here's how the flat black, with the bumper black as a base
(primer) looks on the grill..
https://www.scionlife.com/forums/viewtopic.php?t=177266
Old Jun 3, 2007 | 06:01 PM
Unique Scionikz
Flat black is nice, I want something glossier. It doesn't seem like you used a clear coat though. But the grill doesn't need a gloss.
Thanks for the input! Btw, thats a great write up. I might do that myself. =D
Old Jun 3, 2007 | 09:24 PM
jwaj2002's Avatar
TOCC
why would you spend $30 on lug nuts when you can get them at your parts store for 20?
Old Jun 4, 2007 | 09:43 PM
Yeah, i'm a single stage, flat black, kinda guy, lol.. Thanks for the comment about the grill, post urs if you do it.. later!
Old Jun 8, 2007 | 04:15 AM
bB2NER's Avatar
Music City Scions
No real need to sand them prior to paint. Just wipe em down good with some 90% rubbing alcohol and spray. Get some gloss black duplicolor wheel paint. 2 cans should do all 4 wheels with 2 good coats. Then follow up with a coat or 2 of Duplicolor wheel clearcoat. They will look new.
Old Jun 8, 2007 | 04:48 AM
typhoonorchid's Avatar
I'm gonna try this too. I assume you've done it before 2ner?
My steelies have turned to a dusty charcoal color.
I wanna make em look wet again
Old Jun 8, 2007 | 04:51 AM
___MmmBoxy___'s Avatar
Do what I did. Paint your hubs and rock it!!
~Stephanie
Old Jun 8, 2007 | 04:52 AM
bB2NER's Avatar
Music City Scions
Yes, as long as you remove all the grease and tire goo the paint will stick great. Wipe them down with either brake cleaner, carb cleaner or good rubbing alcohol. After they dry and warm back up spray away and follow the directions on the can. If you sand them first you will have to prime them to fill the scratches. If you are real worried about the paint peeling down the road just spray with adhesion promoter first.
Old Jun 8, 2007 | 04:56 AM
bB2NER's Avatar
Music City Scions
MmmBoxy,
They already have the trim rings, lugs and center caps. Yours are nice but they are still caps and you can tell.
When you painted your caps you should have run 1/2 inch masking tape down the center of the spokes first then clearcoated for a unique look.
Old Jun 8, 2007 | 05:06 AM
I just wanted something simple to do. I was bored.......thanks for the advise though! I might do that next time I get bored!!
And I know you can tell....I'm not trying to fake that they are wheels or anything. haha!
~Stephanie
Old Jun 10, 2007 | 12:43 AM
If you really want the paint to adhere the best it can you MUST SAND the surface to be painted. This does not mean use some heavy grit sand paper. It means use some 320-400 grit wetsand paper to dull the surface and smooth any minor imperfections. You DO NOT need to remove all the paint, just sand, make sure there are no shiny spots and paint the rims.
Old Jun 10, 2007 | 06:37 PM
Yes, Yes, Yes ^^^^^^^
jeremydoc
Sep 16, 2015 11:31 PM
Bhikku
Sep 16, 2015 10:57 AM
jnesselroad
Sep 15, 2015 06:57 AM
peruviann
Sep 14, 2015 06:35 AM
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
