View Full Version : Wheels and Tires
05TC916
09-23-2004, 06:10 AM
Hey guys! Anyone know the correct offset on a TC for a 19 inch wheel with a TRD drop? What is the best tire fit? 225 or 235 35 19? Any problems with rubbing?
mksm2000
09-23-2004, 06:30 AM
what brand of wheels were you looking for?
05TC916
09-24-2004, 06:45 AM
not sure on the rims but i know I want 19's.
Jay
09-24-2004, 04:08 PM
width, offset ect?
chucksu
09-25-2004, 05:31 AM
With a 19" Wheel you want a 215/35R19 as stated by both www.edgeracing.com , www.tirerack.com . www.tire.com shows that a 225/35R19 & 235/35R19 fit :shock: seems a little odd to have a tire that much taller then what the other 2 sites say. As for offset, hard saying. How wide of a rim you going with?
Soon2BxB
09-25-2004, 06:58 AM
all those tires are the same height ... 35 series .... did you mean to say WIDER when you said this
JasonH
09-25-2004, 02:22 PM
The series number ("profile") is a percentage of the width that makes up the height. On a 215/35 the height of the sidewall is 35% of 215mm = 75.25mm. If you increase the width and keep the same profile the tire heigh increases: 35% of 235mm = 82.25mm. So, those three tires are actually different heights.
NJ_05tC
09-26-2004, 01:17 AM
Try this one...tire size calculator,
http://miata.net/garage/tirecalc.html
For my tC...here are the numbers:
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/45-17 3.8in 12.3in 24.6in 77.3in 819 0.0%
225/35-19 3.1in 12.6in 25.2in 79.2in 800 2.4%
Soon2BxB
09-26-2004, 01:28 AM
i stand corrected - thanx for the correction .. learn something new everyday
