scion mechaninc please help!
Old Jun 7, 2007 | 01:13 AM
LostCause's Avatar
Default scion mechaninc please help!
Hi guys
I recently discuused this with another he gave me good advice but i would still like to double check.
Where im at its difficult to get scion parts.
My air/fuel ratio sensor is screwed p2195
The dealer here has a 2006 camry a/f ratio sensor parts number 89467-33040
The scion tc uses 89467-33080.
Are they interchangeable, i understand the tc uses a camry engine.
Please help i ready to buy just need the go ahead
Any help would be seriously appreciated
Old Jun 7, 2007 | 01:55 AM
toyota_scion_tc's Avatar
I wouldn't. I am not exactly sure the difference but I can assure you if it has different part numbers then more than likely one of two things: its not a wide band sensor and/or the resistance is different.
Old Jun 7, 2007 | 02:10 AM
engifineer's Avatar
Have you verified that the sensor is actually bad? There are other causes, like the car actually being lean (I beleive that is the code for the sensor being stuck lean). Make sure you troubleshoot properly before just replacing parts like the dealer would
Old Jun 7, 2007 | 02:13 AM
I forgot I could look up dtc with computer software I have but you are right that is what the code says. It says 02 Sensor Stuck Lean (Bank 1, Sensor 1) which our cars only has one bank with two sensors and the sensor is the one in the header.
Old Jun 7, 2007 | 02:19 AM
LostCause's Avatar
if its stuck lean it means the egine is actually running rich to compensate right?
Thats what the mechanic told me
Old Jun 7, 2007 | 03:14 AM
TcPrincess's Avatar
if the part numbers are different then the parts are different.
Old Jun 7, 2007 | 01:16 PM
Mid_Life_tC-risis's Avatar
For those not familiar with the OP, he stripped the threads on his OEM AFR while installing a header and put in a Denso replacement. We told him to get the exact OEM replacement but he's having difficulty getting one.
https://www.scionlife.com/forums/viewtopic.php?t=177913
This is a new thread for the same problem.
Old Jun 7, 2007 | 01:27 PM
BrEaK_AwaY's Avatar
yea dude like i told ya before. it is the same engine (the 2az), but the sensor is slightly different if the part # is different, but it could be a minor difference, such as a longer wire. but i dont know for sure what the difference is, so i would get the tC sensor
Old Jun 7, 2007 | 03:18 PM
engifineer's Avatar
If it is stuck lean, and the sensor and wiring is good, then it is running lean (hence the stuck lean code). The code is basically saying "I am doing everything I can to richen up the mix to make the proper A/F, but the sensor still says I am lean. So the sensor is wrong or we have an issue getting enough fuel to the cylinders for the amount of air coming in". So it could be a number of issues. If you can smell it is running rich, then that means the sensor is probably bad or the wiring is damaged.
But it sounds like this is a case of a damaged sensor given one of the posts above.
Old Jun 7, 2007 | 04:07 PM
LostCause's Avatar
okay
but how can i tell if the engine is running rich or lean.
the mechanic who read the code said every other aspect is fine idle, etc.
i know i will have to change the sensor.
but i have to run on it till july, but what are the signs to look for on a rich or lean running engine??
tnx in advance
Old Jun 7, 2007 | 05:31 PM
BrEaK_AwaY's Avatar
rough idle, knocking, smell, exhaust fumes, range in rpm's at idle, sound, how easy/hard it is to kick over
Old Jun 7, 2007 | 06:10 PM
LostCause's Avatar
idle'e been pretty stable at around 700 rpms
what type of smell?
and what do you mean by exhaust fumes?
Old Jun 7, 2007 | 06:11 PM
BrEaK_AwaY's Avatar
i cant really describe the smell. but as for fumes, black or white smoke coming out of the tail pipe.
Old Jun 7, 2007 | 06:13 PM
LostCause's Avatar
Luckily no smoke after a ecu reset.
There was a smell from the exhaust i dont know if its normal....kinda like a gasoline smell
Old Jun 7, 2007 | 06:14 PM
LostCause's Avatar
and what do you mean by kick over?
Old Jun 7, 2007 | 06:25 PM
draxcaliber's Avatar
...what do you think exhaust from a gas powered vehicle is supposed to smell like? fresh made cinnamin buns?
Old Jun 7, 2007 | 06:27 PM
LostCause's Avatar
hahaha well i kinda walked into that one
Old Jun 7, 2007 | 06:42 PM
engifineer's Avatar
A strong gasoline smell in the exhaust is a sign of the car running rich. Especially on a car with a catalytic convertor, which usually masks that smell quite well. It will smell more like raw gasoline rather than the normal exhaust smell. That would make me lean towards the sensor being bad, causing the ecu trying to compensate for a lean condition that doesnt really exist.
Old Jun 7, 2007 | 10:11 PM
you can order the sensors online from a ton of places here is a link to two
www.zpiracing.net
www.trdsparks.com
Old Jun 7, 2007 | 10:48 PM
boostaddict's Avatar
first off id fix that asap.. gas going into cat is bad and can lead to needing a cat. also system to lean its the sensor. the heater circuit malfunction can cause that code.. it could be a fuel injector but i 99.9% doubt it. replace the sensor and not that sensor is different.
