Hi and Low beam lights
Old Jun 8, 2007 | 07:06 AM
boxdrvnvet's Avatar
Default Hi and Low beam lights
Ive tried to search for the answer to this but got a quick question. When I put my lights on hi beam, are the low beam lights suppose to stay on? When I pull back about half way on the lever to put the hi beams on momentarily, both the hi beams and low beams are on. I like this much better.
If they are suppose to stay on, any suggestions on where to start looking to fix the problem? Both the low beam and hi beam works great, just not together.
Old Jun 8, 2007 | 07:16 AM
biohazardous_customz's Avatar
I agree they are much brighter with both...but unfortunately that isnt the way they are set up....yours are working fine.
Old Jun 8, 2007 | 07:47 AM
jwaj2002's Avatar
TOCC
yep, yours work fine, I think that if they were set up to run both high and low beams at the same time 1 you would blind everyone and 2 the bulbs would burn out much faster
Old Jun 8, 2007 | 08:30 AM
boxdrvnvet's Avatar
I apparently blind everyone anyway because Im always getting the brights flashed at me. I dont want to run both all the time, just while I would have the hi beams on. Why do you think the bulbs would burn out faster? Would they burn out faster than say running just the low beams or just the high beams?
Old Jun 8, 2007 | 08:39 AM
jwaj2002's Avatar
TOCC
because your burning both elements in the bulbs at the same time, this also makes the bulbs much, much hotter, and the stiff suspension is part of the reason your getting flashed
Old Jun 8, 2007 | 05:12 PM
Mooneyzs's Avatar
Team No Limitz
You can always adjust your light pattern down a little bit, that way you don't get flashed anymore. I did that, and never got flashed again since. I also had put in Silver Stars and they were brighter than stock bulbs.
Old Jun 8, 2007 | 08:03 PM
typhoonorchid's Avatar
Am I missing something. If he has stock headlights it's just 1 bulb, the H4.
Does he have projectors that have high and low bulbs?
Old Jun 11, 2007 | 03:42 AM
peteski's Avatar
Stock xB headlight bulb has 2 filaments built-in. Lo and Hi beam. It is like havng 2 bulbs in one housing.
In majority of cars with this type of a bulb only one filament is turned on at a given time. Some cars which have separate Hi and Lo beam bulbs and reflectors allow for both Lo and Hi beam to be on while using Hi beams.
Old Jun 11, 2007 | 03:47 AM
bB2NER's Avatar
Music City Scions
^^^Yep what he said
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
Pkupman_77
Dec 30, 2014 09:10 PM
SimplifiedScion
19
May 28, 2004 03:40 PM
xBsquared
Nov 2, 2003 09:50 AM
