need help ASAP!
Old Jun 9, 2007 | 04:57 AM
hotboxn's Avatar
Team Echo
Default need help ASAP!
Ok, so i decided to add one of those chrome terminals to my battery to clean up that side of the engine bay a bit. Its one of the ones that you can put multiple grounds into rather than tapping at the top of a post. This one just bolts right to the post itself and has different size holes for different size wires coming off the ground post.
Well, now i just tried to start up my engine and it kind of puttered like the MAF was bad. I let it idle for a bit and it jumped around a lot. Then i jumped in teh car and reved up a bit and it would NOT go past 3 grand. It stops right at it and just acts like its rev limiting right at 3.
Does anyone know what might be causing this? Im supposed to be at work in a couple hours so i gotta get this fixed asap. I'm going back out to the garage right now to put the cables back to the way they were stock and try it again.
Any ideas would be really really helpful.
Old Jun 9, 2007 | 05:14 AM
burstaneurysm's Avatar
Man Justin... I don't know what to tell you...
Have you reset the ECU?
When you installed the ground post, did you accidentally bridge your intake to the battery? That could mess the MAF up pretty nicely.
Old Jun 9, 2007 | 05:23 AM
hotboxn's Avatar
Team Echo
Hey whats up?
Yea I tried leaving the neg cable off the terminal for 10 min then putting it back on then starting up the car again and it still did the same thing.
Lol, no def didnt bridge the intake with the battery. Atleast i hope i didnt.
Old Jun 9, 2007 | 05:26 AM
Have you taken the part off?
Old Jun 9, 2007 | 05:30 AM
hotboxn's Avatar
Team Echo
yea, and put it back to stock and im still having the same problem. I did find a small slit in my intake coupler(rubber piece that goes from the throttle body to the short ram piping. I wish i had some more of that coupling to try and replace that and see if thats causing a vacuum problem. I dont think thats it though because that slit didnt just happen, its been there, just wasnt as noticable.
Old Jun 9, 2007 | 05:34 AM
You could e-tape the slit and see if that's causing an issue... I can't imagine so...
Old Jun 9, 2007 | 05:35 AM
hotboxn's Avatar
Team Echo
I'll try that in the morning, Parents are up _____ing about the exhaust being too loud. Thanks for your help. Guess i wont be working tomorrow...oh well....lol. You going to Night Visions tomorrow night?
Old Jun 9, 2007 | 05:36 AM
I work til 5
but I'm thinking about hauling up there after
Old Jun 9, 2007 | 05:41 AM
hotboxn's Avatar
Team Echo
DO IT!!! I'll hold you a spot if you want or im sure SE will too. They all making the trip up there?
Old Jun 9, 2007 | 05:42 AM
No... it's a pretty slim crowd... I think only 5 or 6 people...
Old Jun 9, 2007 | 05:44 AM
hotboxn's Avatar
Team Echo
ah ok, well i hope you and i both make it up there. I know that a few of my club are making it up there too. It should be a fun time.
Now just gotta spend the day figuring out whats wrong with the car.
Old Jun 9, 2007 | 05:47 AM
Good luck... perhaps I'll see you up there tomorrow
If not, Oakbrook.
Old Jun 9, 2007 | 05:50 AM
hotboxn's Avatar
Team Echo
Yep, thanks again for your input on this. Cya at Oakbrook
Old Jun 9, 2007 | 07:20 AM
hotbox05's Avatar
yeah if there is any air leak in your intake system after the maf then it will definately act like that .
Old Jun 9, 2007 | 12:05 PM
krdshrk's Avatar
Have you tried putting the stock battery terminal back on?
Did you perhaps short out the maf when you were putting the terminal on? If you touched a side to the metal intake or something you could have blown out the MAF
Old Jun 9, 2007 | 12:15 PM
hotboxn's Avatar
Team Echo
I have put the stock battery terminal back on since and it still has the problem. I dont believe that the ground wire touched the side of the metal intake. I'll swing by autozone to pick up a new MAF this morning and I'll try swapping them to see if thats the problem.
Thanks
Old Jun 9, 2007 | 02:29 PM
hotboxn's Avatar
Team Echo
fixed the problem, thanks for your help guys
Old Jun 9, 2007 | 02:36 PM
Dead MAF?
Old Jun 9, 2007 | 05:51 PM
hotbox05's Avatar
wonder how much they are at autozxone , they aren't cheap at toyota for sure.
Old Jun 9, 2007 | 06:12 PM
ElChupacabra's Avatar
sucks you fried the MAF. That couldnt have been cheap to replace....
....much more then you spent on that ground post.
danielv
Aug 26, 2015 07:14 PM
vancouverray
Scion xB 2nd-Gen Wheel & Tire
Aug 10, 2015 10:20 PM
JLOVE1
Jul 31, 2015 02:40 AM
pdxgen2
Mar 14, 2015 01:56 AM
