View Full Version : Someone who knows Subs
ebfoxbat
06-10-2007, 01:17 AM
I have a question for someone who knows something about sub enclosures.
If I'm building a sealed enclosure, does volume matter? I have a great idea but it'll mean that my 8" sub will have very little volume behind it. I'm not concerned with sound levels, just quality. I don't want it to sound horrible.
Thoughts?
dchan8
06-10-2007, 06:19 AM
you should look at the specs provided by the sub manufacturer. They usually call out a certain volume that the sub will work well in.
L4rry_B1rd
06-10-2007, 06:29 AM
of course it matters. too small and it sounds bad, too big and it sounds bad. your best bet is to follow the specs provided by manu.
also make sure you provide enough depth. if the space between magnet and enclosure is too small, the sub may overheat or just sound like crap (friend has this problem and it sounds like he has paper vibrating inside the enclosure because he doesnt have enough depth).
chadfo
06-10-2007, 06:39 AM
The volume always matters. Most new 8" subs require very little air space so you might be able to make your box and have your sound too.
ebfoxbat
06-10-2007, 10:37 AM
Oh how tragically sad. I was going to do something special. There actually could be plenty of volume but very little depth behind the magnet. Is the only concern with depth heating? I could cool it in other ways.
ebfoxbat
06-10-2007, 11:00 AM
http://i11.tinypic.com/66kypfd.jpg
Does that make more sense? I could cool the magnet if the only concern is heat.
I mean if the volume is right it should work right? Even if the depth isn't great?
L4rry_B1rd
06-11-2007, 01:50 AM
It will prob be fine but I still think it will sound like p00p. You should come to one of the MA ScioNRG meets, You can listen to my friend's system. It looks great and sounds ok except the whole vibrating paper thing, lol.
ebfoxbat
06-11-2007, 02:16 PM
I'm going to go with a traditional triangular sealed enclosure. Probably just as easy to make but a less risky design.
Zlog
06-20-2007, 04:54 PM
I direct your attention to this:
Pioneer 10" Shallow-Mount 1000watt Sub (http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069927_297564759_tab=B,00.html?compName=PNA_V3_ProductDetailsComponent)
XBFred
06-20-2007, 05:44 PM
How deep is that box? There are tons of shallow mount subs out right now. The Clarion got a better rating than the Pioneer in CA&E a few months back, and JL is coming out with one soon. Elemental designs also has one.
anyway, check with whoever you get sub from, but you may only need 3/4 inch space behind sub. And you probably don't want to do the fan.
S sub is designed to move air, and if you put a fan inside a sealed box you may create some air movement issues
ebfoxbat
06-20-2007, 07:36 PM
I'm done... bought a box: http://www.scionlife.com/forums/viewtopic.php?p=2659476#2659476
L4rry_B1rd
06-20-2007, 07:39 PM
should've let me fG a small enclosure instead :P
ebfoxbat
06-20-2007, 08:58 PM
ok... I'll give you the same $53 that my empty box cost :)
