what do you guys think of this cap?
Old Jun 12, 2007 | 05:19 PM
scion07's Avatar
Default what do you guys think of this cap?
i dont know very much about systems or anything in cars so yeah, recently my batterie died just randomly im guessing its cause of my subs, i have a 1800 watt amp and two 1000 watt subs stock speakers and headunit, do u think this cap would help? what difference will it make? is it usless for me? any help i would appriciate thanks.
Old Jun 12, 2007 | 05:20 PM
Tcguy85's Avatar
what cap?
Old Jun 12, 2007 | 05:39 PM
cherryBox's Avatar
your battery won't die directly because of just your subs.
Old Jun 12, 2007 | 05:50 PM
tCeeJay's Avatar
cap only helps with dimming lights not with preserving battery
Old Jun 12, 2007 | 05:51 PM
L4rry_B1rd's Avatar
caps dont do anything.
Old Jun 12, 2007 | 06:54 PM
cherryBox's Avatar
Originally Posted by Tcguy85
what cap?
what he said.
Old Jun 12, 2007 | 06:56 PM
Keeshwah's Avatar
I think most people familiar with car audio will tell you a big 3 upgrade is much more beneficial for dimming than a cap. I can attest to the cap not doing a whole lot because I have one and when it was in my old car I didn't see much improvement and I've had no dimming in the tC so far.
Old Jun 12, 2007 | 07:33 PM
engifineer's Avatar
CAPS DO HAVE A PURPOSE IN CAR AUDIO. They reduce the effects of transient spikes which cause very quick dimming of the lights. They do not in any way preserve your battery life, they act as a high pass filter. In most cases you do not need them these days.
Your battery WILL die directly because of powering your subs. If you are overworking your alternator to the point that it is not holding up minimum charge voltage and current, then the battery will be in a discharge state. Typically you will notice a lot of light dimming if this is occuring. If this is the case the ONLY alternative is a higher capacity alternator. Given the connections are good. The alt is providing all of the current plus the charge current needed to charge the battery while running.
A big three upgrade is typically the first thing to start with. 90% of the people thinking they need a higher capacity alternator do not, and they are not pushing near the power they think they are.
Make sure you have good, solid, short grounds. Make sure your power supply wiring is the right size and that it is properly connected. And before anything, make sure your amp remote wire is connected so that the amp is off when the car is... or your battery will be dead in the morning ;)
Old Jun 12, 2007 | 07:37 PM
blazeplacid's Avatar
thats what I was going to say
Possible that you have alot of current being takend from the alt. thus not charging the battery.
Get a DMM and check voltage at batt then at alt. both wtih system off and on
Old Jun 12, 2007 | 09:45 PM
scion07's Avatar
http://www.vminnovations.com/product...tor%2fCap.aspx
Old Jun 12, 2007 | 09:48 PM
scion07's Avatar
well my remote is to a switch which i guessing i left on which cause it to die sorry i forgot to post the link to the cap but thanks for everyones help deffently not getting a cap now
carid
Feb 18, 2015 09:10 AM
Deves
Feb 8, 2015 11:37 PM
AdmirN
Jan 5, 2015 10:19 PM
DjFrOsT
Dec 13, 2003 04:18 AM
DjFrOsT
Nov 6, 2003 04:54 AM
