View Full Version : The end all sticky
SmartAss
06-16-2007, 04:51 PM
First off the dash is exactly the same ___ all the other scions everything works together just fine.
The radio brackets are xA brackets
Dash kit for double din 99-8202 (you have to cut off one screw hole on the side)
Dash kit for single din 99-8209
Harness 70-1761
Factory steering wheel controls can be obtained by using a PAC piece (vary by radio)
Power White Ignition Switch
Start White Ignition Switch
2nd Starter White Ignition Switch
Ignition Gray Ignition Switch
2nd Ignition White Igntion Switch
Accessory Black Ignition Switch
Keysense Blue Igntion Switch or Fuse box (Ground to disarm alarm w/o unlock)
Lock lt. Blue Kick Panel 18pin plug
Unlock Pink " (double pulse)
Parking Lights+ Green Fuse Box Top Left
Reverse Light Red Fuse Box Top Left
Dome light White/Red Fuse Box 6pin 3 white red wires bottom one
Trunk Pin lt. Green Fuse Box Top Left
Tachometer Gray Data Link Connector Pin 9
Parking Brake Black Fuse Box Top Right
Horn Trigger lt Green Ignition Harness or Fuse Box
NO BYPASS REQUIRED
RADIO
12v lt Green
ground brown
ign gray
ill green
ant orange
LF +/- pink - purple
RF +/- lt green - blue
LR +/- black - yellow
RR +/- red - white
Front doors
1" Tweeter and 6 1/2" Speakers
Rear Doors
6 1/2" Speakers
VSS Wire Behind Radio 20 pin plug PURPLE wire Pin 3
This is the wire Randode did cut to make his nav work I did the same and it works, the headunit does not require the speed sense wire to be hooked up becuase it already is and its that wire. The reason they give you a purple/white wire is becuase its cheaper to keep in in the harness then make a new one.
(not 100% but pretty sure that has to be it)
Best to attach a switch so if you arent watching a movie you can switch it back so the radio has speed sense again even though it works fine without it.
Must also ground Parking brake wire.
The factory beeper is a Blue wire on the drivers fender you can pull it off and over into the engine bay.
jarero
06-16-2007, 06:17 PM
Awesome post! I wish I had known the rear doors were 6.5" before I ordered my 5.25" speakers online on the advice of another poster.
Max
06-16-2007, 06:21 PM
Good information... I stickied it.
SmartAss
06-16-2007, 06:43 PM
Any other info needed just post it, Im working on a bunch of 08 xbs right now and should have everything done between all 3 of them.
Malibu_Rapper
06-17-2007, 09:02 PM
It was probably my advice. I saw this sticky and it had me concerned so I went outside to do better measurements. Now, given I haven't taken the speakers out, I can see through the grill that the rear speaker is smaller than the front. So I decided to snap a picture with my dial caliper set at 5.25" and also take a picture of a 5.25" Peerless speaker with the same settings. The first picture you can clearly see the cone, it is the silver round portion behind the grill.
http://www.pldlawyers.com/bp/scion/xb2/misc/IMG_0073RS.jpg
http://www.pldlawyers.com/bp/scion/xb2/misc/IMG_0074rs.jpg
So unless my eyes are deceiving me or the speaker has some strange surround, this looks like a 5.25" speaker to me. Not saying that a 6.5" cannot fit, but this speaker has a significantly smaller cone area compared to the front speakers and the cone area is very similar to the 5.25" speaker in the picture above.
Malibu_Rapper
06-17-2007, 09:10 PM
Do you know what wire it is for the passenger unlock motor? This wire is needed for add on security using OEM keyless so that the alarm cannot be disarmed via the unlock switches on the doors.
Thanks
SmartAss
06-17-2007, 09:41 PM
The hole in the rear door is the same size as the hole in the front door and the factory speaker is a 5 1/4" speaker but even using a 6 1/2 you still need a adapter to make it fit into the hole correctly. The grill on the door doesnt cover anything on the speaker other then the rubber surround which doesnt make a difference musically which is why I say its best for a 6 1/2" speaker
No idea on the passanger unlock wire but if you pop off the door panel you will see its one of the wires attached to the factory actuator. It will also be found in the passanger kick plug that contains the lock and unlock wires.
Malibu_Rapper
06-17-2007, 10:27 PM
Ok that makes sense. So the factory speaker is a 5.25" and the 6.5" speaker reference for the rear doors in the original post is just a recommendation, not the factory speaker size. If you could take some shots of the doors with the panels off, that would be great.
Also a little concerned about speaker depth on the rear doors, does it have to clear the power windows and if so how much depth do we really have?
Thanks for the info...
Bigfieroman
06-18-2007, 03:33 AM
A few pieces of info from my AVIC-D3 install.
I used the metra 8202 kit from Crutchfield. It fit without hacking off any bolt holes. Not sure why you would need to.
The purple wire that Smartass suggests could be the speed signal wire is indeed the correct wire. I used it and confirmed the unit was receiving signal. This was originally suggested by Randode, thanks to them both.
The red wire used for reverse signal in the factory nav install worked fine for reverse signal.
The location used in the factory install for the GPS antenna worked great, completely hidden.
Factory install: http://www.trdsparks.com/install/08545-00930inst.pdf
The PAC accessories for making the steering wheel controls work are installed exactly the same as in the old xB.
BigBHaller
06-20-2007, 02:07 AM
Thanks for the confirmation! I should be receiving my Z2 and install kits this week so I should be doing the install on Sunday. Hopefully all goes well with the help of this information! :pray:
dasaint80
08-05-2007, 03:42 PM
Great info Smartass!!! You the Bestest!!!!
vertastang
08-10-2007, 10:26 PM
not the right wiring for the 08's. i installed a preamp in to my factory harnness and went by this code and it was wrong i will post the right one.
Dont follow this if u plan on installing a RCA converter in to your factory deck,!!!
RADIO
12v lt Green
ground brown
ign gray
ill green
ant orange
RR +/- red - white
vertastang
08-10-2007, 10:37 PM
AS i said here is the right one guys!! hope it helps!!
http://i4.photobucket.com/albums/y108/vertastang/wire.jpg?t=1186781693
detroitbassxb
01-22-2008, 05:08 PM
Awesome guide guys, thanks!
ibnboxin
02-06-2008, 03:30 AM
asdding this to this section as i do not know where else to put it
http://www.scion.com/assets/pdf/audio/200708_base_owners_manual.pdf
buickid
11-05-2008, 08:04 AM
Figured I'd put my Big 3 tutorial here. Lots of good pics inside! :)
http://www.scionlife.com/forums/viewtopic.php?t=241097
miketf1
01-27-2010, 09:19 PM
posting this here. i found this in my messages from way back when. useful cause since the move, many threads were lost..
http://www.scionlife.com/forums/viewtopic.php?t=187351
thats for the gauge cluster
http://www.scionlife.com/forums/viewtopic.php?t=195379
thats for the shift column lights (PRNDS+-) if you have a automatic
http://www.scionlife.com/forums/viewtopic.php?t=201377
thats for the MODE button on the steering wheel
http://www.scionlife.com/forums/viewtopic.php?t=187980
thats for the A/C knobs
as for changing the color of the buttons on the headunit, its only an option with the "premium" the basic and the navi dont have this option. if you do have the premium turn it off with the PWR button (no tricks here) then press and hold the MENU button and it will beep and a "secret" menu will pop up. then scroll over to ILLUMINATION and select blue.
