View Full Version : Pic: TWE oil catch can
streetlethalxb
06-17-2007, 05:17 PM
I installed my TWE oil catch can today, nothing special.. I had to use some of my own hose to reach where I mounted it, but all in all, its cool..
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_2442.jpg
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_2445.jpg
and under the cover plumbing..
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_2440.jpg
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_2441-1.jpg
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_2444.jpg
black_sand_box
06-17-2007, 05:45 PM
I'm sorry for my ignorance but what is the purpose? Is it supposed to be a solution to engine blow by? I've always thought that only high milage vehicles have blow by problems.Clean engine by the way.
g0nk
06-17-2007, 06:04 PM
I was just about to ask the same question.. I have no idea what they're for.. :)
streetlethalxb
06-17-2007, 07:29 PM
It catches the oil blow by in the PCv system, before it enters the intake.. Will take roughly 60 thousand miles to see the difference it makes..
black_sand_box
06-17-2007, 08:48 PM
WTF? You're telling me that these motors have blow by problems at 60K? It doesn't say much for the motors that we have!If that's true that is.
streetlethalxb
06-17-2007, 08:53 PM
its not a blow by problem, it is a natural occurance in the
PCV, positive crankcase ventilation system, cars at 60k
miles or more develop deposits in the manifold, like all cars
with a pcv system, these deposits after time create poor
performance and valve deposits.. the catch can, helps reduce
that... its not piston blow by like i think you are refering.
"Oil Catch Tanks collect the oil, moisture and blow-by gas
that causes carbon and sludge build-up in the intake system
and engine to keep them clean even under the hardest driving
conditions."
streetlethalxb
06-17-2007, 09:19 PM
p.s. its not at 60k that it starts, its just around then, the small deposits made by the system have collected into heavy deposits, that deplete intake performance.
moderngti
06-18-2007, 03:51 AM
for like $6 at any GM dealership they will sell you a "top engine / cyl cleaner" for use while de-carboning it.....
way cheaper than a catch can.....
streetlethalxb
06-18-2007, 10:51 AM
I use that top engine cleaner "crap" on a daily basis at the shop,gets 10-20% out, if your lucky, and for the $24 this cost me, its worth never getting sludged up to begin with..
Gothbox
06-19-2007, 02:32 AM
ok so my xB has 88,500 miles on it how can I "clean" the engine? And looks like I should get me one of these. Where did you get yours?
frogbox
06-19-2007, 02:40 AM
hey Goth, you can try seafoam, or the older method of putting 1/2 qt #2 deisel in the crankcase, let it run for a little while, don't drive it,don't rev it, just let it idel and then do an oil change. USE THESE METHODS AT YOUR OWN RISK AS I ASSUME NO RESPONSABILITY FOR ANY DAMAGES YOU DO TO YOUR OWN CAR.!!!!!
seafoam here.......http://www.seafoamsales.com/
Gothbox
06-19-2007, 02:43 AM
what is this "seafoam" stuff?
streetlethalxb
06-19-2007, 02:50 AM
Thats the thing, cleaning that stuff out can be difficult, the can, for the most part, takes it out of the picture. The best thing you can do, is get some top engine cleaner, and you will need a hose from the bottle, to the brake booster vacuum line, idle the engine untill it sucks it all down via the vacuum line, shut it off for 20-30 minutes, then start it back up, it will bellow smoke and misfire, but thats all the crap coming out. Feather the gas to keep it running, until it will idle on its own, when the smoke stops, go rip it around the block, and thats it.. repeat as neccessary, the manifold is one thing, but getting the buildup off your intake valves may require several treatments..
http://cgi.ebay.com/ebaymotors/Universal-Blue-Oil-Catch-Tank-Can-MR2-Supra-IS-TC-XA-XB_W0QQcmdZViewItemQQcategoryZ6778QQihZ013QQitemZ230142915339QQrdZ1QQsspagenameZWDVW
ok, so they are $32 and not $24.. oops
Big_Bird
06-19-2007, 02:53 AM
ive been looking to do this for a while, what all was involved in your instalation?
Gothbox
06-19-2007, 02:59 AM
So I can get this top engine cleaner at the local Auto Zone? is there anyway that you can point out what vacuum line you are talking about?
Thank you for all the info. :bow:
streetlethalxb
06-19-2007, 10:18 PM
Heres a pic of where to hook it up, tomarrow at work I will get one of the hoses we use to attch the bottle of cleaner to the line, and as far as what to buy, let me post that tomarrow too.. I have only used Wynns, and dealer specific stuff.. I will say the dealer stuff is the strongest i've used.. whatever manufacturer. But, i'll post that tomarrow. Also, usually you would dump a can of throttle body cleaner through the TB, at the same time, making sure to completley clean the throttle plate and where it seats to the TB..
Hope this helps Gothbox!!
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_2451tag.jpg
streetlethalxb
06-19-2007, 11:07 PM
It took all of 15 minutes, I removed the engine cover, and I had to use some hose I had lying around to make it reach where I mounted it, I didnt even have to drill any holes to mount the can, there was a small hole on the inner fender I used to send a self tapping screw through.. and i needed a large vacuum line coupling to attach the stock line to the blue line (which i also had lying around).. was easy and is worth it.. I had originally wanted to build my own catch can, but copped out when i got an ebay gift certificate for my birthday, and just bought one..
Mugetsu
06-19-2007, 11:23 PM
Hey streetlethalxb that blue hose is gonna collapse under regular engine bay temps...especially running that close to the valve cover. you should swap it out for what you used on the other line, which i'm guessing is regular old school "NON" EFI fuel line.
by the way how often would you need to dump it on a NA set up? i have a TC by the way...
http://i172.photobucket.com/albums/w15/Mugenji/catchcan.jpg
Gothbox
06-19-2007, 11:37 PM
[quote="streetlethalxb"]Heres a pic of where to hook it up, tomarrow at work I will get one of the hoses we use to attch the bottle of cleaner to the line, and as far as what to buy, let me post that tomarrow too.. I have only used Wynns, and dealer specific stuff.. I will say the dealer stuff is the strongest i've used.. whatever manufacturer. But, i'll post that tomorrow. Also, usually you would dump a can of throttle body cleaner through the TB, at the same time, making sure to completley clean the throttle plate and where it seats to the TB..
Yes this helps alot and sums it up.
Thank you, and I will be looking for the other info as well.
:bow:
streetlethalxb
06-20-2007, 12:10 AM
Yeah, i was wondering about that line, but I ran it on the intake side of the head for that reason, it seemed a little more stout than the silicon line I have also running off the valve cover.. I most likely will switch to the fuel line (yes old school, left over from a 75 Stingray project), I also have a few rolls of braiding in the garage, when I do switch, I think I will also braid it all, with the blue hose clamp covers..
Edit: I just noticed yours (looks good BTW) is sideways, so I would check it sooner, seeing as how it has less to go before it drains back into the line, just pop off the low line every now and again and check it for oil drain back..
shouldn't be drained too often, its not like the old school PCV systems that would fill 'em quick.. I'm honestly guessing 60k miles from the install.. we'll see
frogbox
06-20-2007, 04:45 PM
streetlethalxb,
After a close examamination of your install of the catch can, it looks like you installed it incorrectly, an oil catch can should be , if i remember correctly, in the PCV line, not the brake booster vaccum line. were there instructions that came with it?
streetlethalxb
06-20-2007, 10:37 PM
No No, its installed correctly at the pcv, I was explaining to gothbox where to hook up for a induction system cleaning (at the booster line), but i'm all good.. Thanks though
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_2441-2.jpg
streetlethalxb
06-20-2007, 10:40 PM
UPDATE:
I got a CEL light today.. it was for a too lean code (i love owning a scanner), it turned out to be the threaded fittings at the catch can were sucking air, so I teflon taped them up.. no more CEL.. (it took about 10 miles to produce the code, test drove for 20 after the repair)
frogbox
06-21-2007, 03:20 AM
I see where it is different from " standard" installs now. In your picture the blue hose from the intake to the head is in a different connection than every other line I have seen or installed. the line with the PCV valve is usually the line connected to the intake. i just noticed that you connected yours differently than all the others I have ever seen.
The catch can should be hooked up to the PCV, not the breather pipe. Air is drawn in through the air box and into the valve cover. From there, the blow-by vapor (unburnt sludge and ____) exits through the PCV and is drawn via engine vacuum into the intake manifold. The catch can acts as a filter between the PCV and IM to catch the blow-by vapor before it builds up in the IM over time.
Mugetsu
06-21-2007, 08:28 PM
^^^ well usually valve cover PCV systems have an "intake side" and a "exhaust side" so to speak... the side conected to the intake lets air IN while the side connected to the intake "manifold" lets air OUT.
it would be pointless to attach a catch can to the intake side, maybe a breather filter(eh...) most of the blow by is in the OUT line of the PCV system.ALL scions use this system, and as far as i know all other vehicles do as well...
streetlthalxb...A LEAN CEL from a catch can is pretty scary, that must be a decent sized leak...
Thats the one good thing about the WR uni tank, its pretty much welded with few screw on parts.
cherryBox
06-21-2007, 08:39 PM
hey, did you happen to check to see how well the can was sealed before you installed it? I've tried a couple of different ebay catch cans and when i plugged one of the valves and blew into the other, I found leaks every time. Introducing a leaky catch can into a vacuum system is no good.
edit: duh. you already figured that out. I didn't see the second page, my bad.
streetlethalxb
06-21-2007, 10:19 PM
ok..
The leak was severe.. due to me just assuming the brass fittings were secure and not checking.. when I got the CEL, I looked and one was very loosely threaded in, and not tight at all.. so I proceede to repair that.. other than that I dont see where any future leaks would come from, the system is sealed..
It may look like a different install because of where I put the can, most are by the battery or on that side.. I had to run long hoses to the other side of the engine bay, and i used a coupler to attach to the stock line (scince it is that wierd size on either end)..
GOTHBOX:
Heres the pic of what you need to find or build to correctly clean your intake.. It will need a flow control, otherwise it will suck in way too much and die, etc.,.
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_24522.jpg
Now to be completley off the subject
I had my camera at work so heres a pic of my toolbox in the middle of a busy day, dirty dirty
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_24532.jpg
And heres a pic, of my favorite sight at work, my box standing alone in a sea of hondas (they all want to race me)
http://i182.photobucket.com/albums/x254/streetlethalxb/IMG_24542.jpg
black_sand_box
06-21-2007, 10:56 PM
That is a wicked nice tool box!
streetlethalxb
06-22-2007, 02:11 AM
Thanks!! It's a reminder to myself to buy my dream bike... one day..
jallamas
06-04-2008, 09:37 PM
Nice info!
Thx
John
jct
06-05-2008, 12:07 AM
Nice info!
Thx
John
yeah thats nice
<<< me mister obvious haha :P
jallamas
06-05-2008, 06:35 AM
Nice info!
Thx
John
yeah thats nice
<<< me mister obvious haha :PI thought you would like it!
John
