View Full Version : looking for slotted drilled rotors
davematic 06-19-2007, 10:05 PM im looking to by some slotted/drilled rotors .
does anyone have them ?
do i just by the rotors that will fit a tc ?
or the ones that would fit the camry ?
your help is appreciated
jallamas 06-19-2007, 11:16 PM ebay! :silly:
davematic 06-20-2007, 02:28 AM ebay! :silly:
i always check ebay
what i meant is that i need to know if the tc rotors fit it or the camry.
there is no listing on ebay or anywhere that i've seen that says "08 scion xb slotted/drilled rotors".
i wouldn't want to purchase the wrong part
eight08customs 06-20-2007, 02:59 AM from what i heard the rotors are the same as a Rav 4
lastlookcustoms 06-22-2007, 01:33 PM from what i heard the rotors are the same as a Rav 4
Yup, rotors are the same as 06-07 Rav...
skullsandcandy 06-22-2007, 03:40 PM Do they really make slotted rotors for the Rav4? I never would have thought of that.
rsw1124 07-09-2007, 12:21 AM http://www.autopartsway.com/performance/spartdetails.cfm?ID=E35GD7232_21453
Good Luck if anyone is still looking!!
ScionFred 07-11-2007, 02:34 AM im looking to by some slotted/drilled rotors .
TRD offers a performance brake kit for the XB2. It includes larger drilled rotors, red TRD calipers and SS brake lines. I don't know the cost but any dealer parts dept. should be able to look it up.
rsw1124 07-11-2007, 11:19 AM that product seems to have disappeared from even sparkstoyota. Was there when first released but could not find it so use Rav4 and the above link. Have not made that paurchase yet but is next probably in fall. Good Luck. I had seen it originally but is no longer there so checked around.
BloodHoundFan 07-11-2007, 11:27 AM Yeah, I don't see it online at all anymore. I did see it about 2 weeks ago in a TRD print catalog at the scion dealer. Maybe it is just delayed or they decided to drop it?
Ldrett 07-17-2007, 12:42 AM I have been wondering about cross drilled rotors as well. I can find them for a Rav 4 up to 2005. Are 2006-2007 Rav 4 rotors different? Will they work all the way around?
RADIOEAST 07-23-2007, 02:01 AM Posted: 7/16/07 6:42PM Post subject: Rav 4 springs
rsw1124 07-23-2007, 11:30 AM http://item.express.ebay.com/_Car-Truck-Parts-Accessories__Toyota-Rav-4-06-2-4L-drill-slot-brake-discs-rotors_W0QQitemZ140140171837QQihZ004QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQptdiZ2865QQcmdZExpressItem
check this out!!
Jayrock39 07-23-2007, 11:35 AM I would try Powerstop rotors and would stay away from cross drilled. Just use slotted. Cross drilled can overheat and crack easier under continuous heavy braking. A friend of mine used to race an Integra with cross drilled and cracked 3 different sets.
davematic 07-29-2007, 03:36 AM http://item.express.ebay.com/_Car-Truck-Parts-Accessories__Toyota-Rav-4-06-2-4L-drill-slot-brake-discs-rotors_W0QQitemZ140140171837QQihZ004QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQptdiZ2865QQcmdZExpressItem
check this out!!
i wouldn't recommend to get rotors that are dimpled. they have a tendency of being noisy.
make sure that they are drilled all the way thru.
these rotors where pm'ed to me a few weeks back .
http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductBrowse?storeId=10101&Pr=p_Product.CATENTRY_ID%3A2008488&productId=2008488&tf=Browse&N=111%2B200729287%2B2006%2B600015954&catalogId=10101
rsw1124 07-29-2007, 11:27 AM yeah i think that was me but look at note on bottom. THis item not available. Had not seen that when I sent it to ya.
JoeSpeed 10-18-2007, 05:43 PM cross drilled rotors don't crack easy. I had them and they out last any other rotors I ever had. Important: Don't get cross drilled slotted combo those, I saw in a car show the said they can crack easy. cross drilled can hold temp up to 1,700 degress F. they are used for better braking under extreme conditions. Slotted are just good to keep them cleaner.
