Sharp corners=ripples???
Old Jun 21, 2007 | 05:05 PM
chicotunner07's Avatar
Default Sharp corners=ripples???
I was washing my car the other day, and right above the rear/right wheel, on the 1/4 panel, there were ripples...... i cant feel them or see them up close, but at an angle u can clearly see them?? Could it be from hard cornering? has anyone else experienced this, maybe everyone should check on this, cuz my friends noticed it too??? WTF
Old Jun 21, 2007 | 05:07 PM
engifineer's Avatar
ripples? Do you mean irregularities in the paint?
Old Jun 21, 2007 | 08:10 PM
no, i mean like a can of soda crumpling ever so slightly, you can only see it when u stand by the front and look at it at a slant
Old Jun 21, 2007 | 10:35 PM
falkor's Avatar
Sounds as though it is the paint . Could be normal paint lines . If it is the Azure Pearl , most likely it is normal . If it is dark , could be a slight indention which causes ripples . Hard to say without being able to see it .
Old Jun 22, 2007 | 12:57 AM
paul34's Avatar
Does it look like the surface of an orange?
If so, what you're looking at "orange peel." It's normal on most paintjobs, unfortunately.
You really don't get very high quality paintjobs that are 90% or more lacking in orange peel until you go to paintjobs like that found on the LS460, or Buggati Veyron. Alternatively, you could wetsand any paintjob all the way to the level of the "hills" and then try to even it out... but the amount of clear coat you'd have to take off usually means it isn't worth it (will make for early clear coat failure even with proper care and application of waxes/sealants)
Of course, if you think our orange peel is bad... go look at a GM
Old Jun 22, 2007 | 01:00 AM
paul34's Avatar
rather severe orange peel looks like this:
Of course, if you have no idea what I'm talking about, you probably won't notice the defect in your paint. But if you have someone who knows point it out to you, you won't be able to stop noticing and rating orange peel on any car
Old Jun 22, 2007 | 01:11 PM
No , definitely not orange peel!!, i guess ill try to take pictures hopefully it shows up on camera, but its definitely there!
Old Jun 22, 2007 | 01:38 PM
Olorin9's Avatar
I'm thinking he means the light reflection ripples at an angle?
BlingSlade
Oct 19, 2016 12:39 AM
dougcbx
Oct 23, 2015 11:42 PM
prescottn
Oct 8, 2015 05:31 PM
prescottn
Sep 13, 2015 09:04 PM
