Installing AEM intake
Old Sep 28, 2004 | 05:06 AM
bb_tOmmie_dd's Avatar
Default Installing AEM intake
sorry if this was brought up already? but can someone tell me the steps to install a AEM intake for a xA. like the air sensor and etc? tommiehilfigrr@yahoo.com
thanks
Old Sep 30, 2004 | 05:33 PM
anyone????
Old Sep 30, 2004 | 05:46 PM
Cameron's Avatar
I'm assuming that you're installing the gen 1 dealer version AEM intake designed for the XA and XB.
Are you stuck or do you need OEM air box removal and AEM installation steps? I installed my own AEM dealer version on my XB, but it came with fairly easy to follow instructions.
1. remove battery
2. unscrew and remove MAF and VCV. Be sure not to touch or damage the MAF center sensor.
3. remove air box. top comes off, remove filter, unscrew 3 bolts in the bottom of the air box.
4. remove transmission bolt and replace with AEM transmission bolt while attaching main pipe.
5. loosely fit other piping on and adjust for clearance. tighten. go faster.
These instructions are VERY cursory and from memory. I may have left some things out.
Old Sep 30, 2004 | 05:59 PM
TOAST3R's Avatar
where did you get your aem intake? mine came in a aem box and had install instructions in it from aem. contact them for install instructiions
Old Oct 1, 2004 | 03:43 AM
clipper453's Avatar
Default K&N CAI Instructions
Don't know if it will help, but here's the instructions to install a K&N CAI. I would have to think that some/most of the steps would be the same with the AEM CAI.
http://www.kandn.com/instructions/69-8605.pdf
- Clipper453
Old Oct 1, 2004 | 04:59 PM
clipper453's Avatar
Default xA Instructions
My bad. You wanted instructions for the xA (not xB). Here's a link to xA instructions for a K&N CAI. Again, some of the steps should be the same as the AEM CAI.
http://www.kandn.com/instructions/69-8606.pdf
- Clipper453
Solowcal_tc1
14
Feb 27, 2024 06:23 PM
Frustratez
Feb 26, 2015 04:03 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
Besk_one
12
Nov 17, 2003 10:29 PM
yanges
16
Sep 26, 2003 06:01 PM
