Have HD Radio? Need advice/help/info.
Old Jun 25, 2007 | 11:37 PM
miggy's Avatar
Default Have HD Radio? Need advice/help/info.
I have the Kenwood Ez900hds it has the built in HD radios tuner built in. When it gets the signal it's great it sounds good, though it does not hold for very long. It comes in and out even if I am in an area that I get good reception when I stop it will loose it and go back to analog. When it does go back to analog it sound really bad and very staticky, and these are areas that sounded good when I had the stock stereo in. So that said here are my questions:
1) If you have HD Radio, do you get this problem? Whatever your answer is please say
if its built in or you have the add on box?
2) If this persist I am switching out the stereo for something else. So which stereos
do you have and are getting good if not great FM reception?
I understand the signal will not be everywhere, but if I am receiving the signal it should come through in that spot driving or stopped. I don't see why it would lose the signal if I am stopped. I live in West Los Angeles if that if that helps with something. Any more info needed, just let me know. Thanks
Old Jun 26, 2007 | 12:08 AM
SanchezHacker's Avatar
Perhaps the antenna isn't getting the power it needs. Check out this post for more info.. https://www.scionlife.com/forums/viewtopic.php?t=155504
prescottn
Oct 8, 2015 05:31 PM
dyenfd
Sep 13, 2015 10:00 PM
rhino8648
Sep 6, 2015 04:04 AM
10spokess
Aug 16, 2015 02:50 AM
semlin
Jul 29, 2015 02:07 AM
