superboxcarxb
06-27-2007, 09:56 AM
Where do i go to get a recon permit on oahu??? Everybody says i need one to add my intake and exhaust to my car. Where do i go and how much does it cost to get one??? :tap:
View Full Version : RECON PERMIT superboxcarxb 06-27-2007, 09:56 AM Where do i go to get a recon permit on oahu??? Everybody says i need one to add my intake and exhaust to my car. Where do i go and how much does it cost to get one??? :tap: satoman44 06-27-2007, 08:30 PM no need recon for intake/exhaust :D however, if you have suspension work done, you need to get it. Varsis 06-28-2007, 03:38 AM not from what i heard on the phone message from the recon permit office. is there anywhere we can get proper state information on it? superboxcarxb 06-28-2007, 09:28 AM i sent a message to city hall and they didn't reply. My brother got pulled over for his intake on his xa. They said he needed a recon. So, just to be safe, i want to get one. I think you're supposed to get them at the police station. superboxcarxb 06-28-2007, 09:30 AM anything that didn't originally came with the car, needs to have a recon permit by what i have heard.... Varsis 06-28-2007, 10:27 AM From what the message stated anything that wasn't a FACTORY part you need to have a recon done. The recon needs to be re-done after any new changes to the cars power train or suspension. Cosmetics aren't affected in the recon from what i understand. So this leads me to believe that if we use a complete list of TRD parts we are NOT subject to recon as they are factory parts for the car. This includes lowering springs exhaust intake etc. Might make me go with nothing but TRD parts for this car when they start putting them out for the 08 tC. Last but not least this makes me think NO RECON is required when getting the factory super charger installed. Teehee! noservice2001 06-28-2007, 02:58 PM http://www.forumshawaii.net/vbb/showthread.php?t=309267 superboxcarxb 06-28-2007, 06:26 PM Someone told me you don't need recon for intake/exhaust, which is all i will be doing for my car. I'll just trust him on that b/c i don't want to get a recon. lol. superboxcarxb 06-28-2007, 06:34 PM Originally Posted by crj341 I've heard a lot of contradictory information from friends, etc, so I decided to go to the source and call the recon office. I talked to Kevin down at the recon office about what mods you can and cant do, and of those which ones require recon. I hope this will clear up the misinformation that you might have heard and help you plan your next or current project and not be dissappointed cuz you didn't pass. Do I need to get recon for a turbo/supercharger? No. Whether it comes as a kit or you put it together yourself, you can legally put a turbo/supercharger on your car and DO NOT have to get recon. However if you have to get recon for one of the reasons below, just make a note of the turbo/supercharger. Are engine swaps legal, and do I need to get recon for it? That depends. Yes engine swaps are legal, but that does not necessessarily mean you have to get recon. If the engine you are swapping in has the same number of cylinders as the one it is replacing, recon is NOT required. It doesn't matter if the engine you are swapping in is turbocharged. For instance, you want to swap a SR20DET into your 240sx. This does not require recon. However, if you want to swap a RB26DETT into your 240sx, you WILL need recon. Can I put on rims bigger than 1.5" compared with stock? Yes, but you will have to get recon. You can go as big as you want to, but the wheels have to be able to turn and not rub the fenders or wheel well when turned. Do I have to get recon for my headers/exhaust/intake? No. These are not recon items. And even if you did, any intake/exhaust will likely pass as long as the exhaust isn't too loud (they don't have any DB meters down there, they just listen to it). If your car is fitted with a catalytic converter, you will still need a cat, but you can use an aftermarket high flow type and still not need recon. Can body kits/panels/hoods be installed? Yes, and you don't need recon. One caveat here though, if your fiberglass/carbon fiber hood does not have provisions for windshield washer nozzels and you don't put them in, you would not pass safety, let alone recon. Are coilovers/lowering springs legal? That depends. Any time you have suspension work done to your car, you will have to get recon. You will need to have an alignment done within 30 days prior to your recon inspection. Make sure you bring a copy of the alignment sheet with you. Your suspension must be able to be aligned within stock specifications. Your car will also be subjected to a "bounce test" to check for adequate suspension travel. They typically test this at a front corner by pushing down on the bumper. You need to have VISIBLE (not necessarily 2 inches) of suspension travel. If your springs are too stiff, you will likely not pass. Are headlight/tail light swaps/conversions legal? Yes, as long as it says DOT on them. Simply doing a headlight/tail light swap does not require you to get recon. If you modify the donor headlight, then it is no longer DOT legal. Aftermarket HID's are also legal, though you may need recon for this. They have a light meter to make sure it's not too bright. Are clear corner lights legal? No. The lights MUST have an orange reflector at the front corners and corresponding red reflectors at the rear. This is a FEDERAL LAW. Simply putting in an orange bulb DOES NOT make it legal. Most of these aftermarket lights do not have DOT on them, and therefore would not pass anyway. If you modify a DOT corner light by taking the orange reflector out, it is NO LONGER DOT legal. Can I run nitrous? No, and it can't be made legal by going through recon. If you did have to get recon for suspension mods, and they happened to find a nitrous line or bottle, you will fail. Can I change my car from front wheel drive to rear wheel drive? Yes, but you will need to go through recon as this will require modification of the vehicle's suspension. If you did a hack job with the conversion and the inspector deems your car unsafe, then you won't pass. If there's a version of the car with a different drivetrain, can I use it? Yes. If the car came from the factory with the option of a manual or automatic transmission, you can swap one for the other without getting recon. You could also do a 4 wheel drive conversion on your 2 wheel drive truck if there was a 4 wheel drive version of your truck from the factory, provided the parts bolt in without requiring custom fabrication. If custom suspension mounts need to be made, or you use aftermarket suspension components, then you need recon. Are intake manifolds/cams, pistons, etc legal? Yes, and you don't need recon. There's no smog testing in Hawaii, so you don't need an affadavit showing that the part is 50 state legal. But be aware that if it says "off road use only" on any of the parts, and the inspector sees it, you will likely not pass recon even if you were trying to get it for something else. Do I need an affadavit for all of my modifications? No. Affadavits are no longer required. Is there a headlight/liscense plate height requirement? Yes. Headlights must be at least 22" off the ground to the center of the headlight housings. You must have a front liscense plate which must be at least 12" off the ground. Do I have to get a recon inspection every year? No. It's a one time only thing UNLESS you mod your car again. If you do, then you need to get another inspection. If you return your car to stock again, you no longer need the recon sticker. If a cop pulls me over saying I need to get recon even though I don't have any recon items on my car, what happens? If you got pulled over for a non recon item, you can contest the ticket in court and you will win. Kevin says many of the cops don't have a good handle on the recon law themselves. Keep in mind though, if you already have recon and do another mod to your car that requires recon, then you need to get another recon inspection. If the cop nails you on something you just installed, then you're SOL. Hopefully this will clear up a lot of the BS that has been floating around. If anyone has any questions about a modification, it is in your best interest to call the recon office (733-2542) and speak to an inspector BEFORE you spend the time and money. As you can see, you can do a lot of mods to your car and not need recon. But if your mod requires it, make sure your mod will be able to pass by reading the thread. superboxcarxb 06-28-2007, 06:35 PM Ha! I found a good post! :) satoman44 06-28-2007, 06:45 PM see, told you :P if you ever need recon though, you have to go to the recon station on kapahulu under the freeway. Varsis 06-28-2007, 07:02 PM So, I finally got a hold of an inspection agent, they are mainly concerned about suspension and tires etc. Intake, exhaust, headers were stated as not needing a recon. Oh, and in regards to the suspension, you'd still need a recon even with all TRD parts or the like. superboxcarxb 06-28-2007, 08:48 PM well that sucks. another mission completed....lol. _eE_ 06-30-2007, 05:01 AM the license plate no longer has to be 12" above the ground. superboxcarxb 06-30-2007, 07:59 AM do we still need a front license plate? noservice2001 06-30-2007, 08:23 AM yes.... and it needs to be 12" from bottom to ground.... so if your car is uber low... just put the two top screws on the bottom ones for your recon test... i was told to do that for my rolla, the top was blocking my grill, it was soo ugly, but i got my recon passed then you can take it off after.... if you wanna chance em katchkillah 07-09-2007, 08:40 AM as for the license plate. lingle just signed a bill where there's no minimum height for the plates now. due to many new high end cars having the plates lower then 12". probably an official got cited for too low of a plate and decided that was no longer needed. LOL. so you could run your plates 1" off the ground now. i know some who are doing it now. noservice2001 07-09-2007, 08:47 AM what are the chances tint laws have changed recently? superboxcarxb 07-09-2007, 08:58 AM Gee, that's a little too late for the license plate thing for me!! i've already drilled holes in my front bumper for the damn thing.....F lingle and her stupid laws!!! katchkillah 07-09-2007, 05:15 PM tint laws still the same. but for xb's we are classed as mpv (like vans and suvs, we can have what ever darkness from behind the driver and the front passenger windows. so as long as those to are legal shoots you could spray paint your back windows black and it would be legal. oh and nothing on the front windshield for sure. noservice2001 07-09-2007, 11:54 PM nothing on the front windshield for sure? what about 4" or the AS-1 line? katchkillah 07-10-2007, 07:02 AM not sure on the 4" thing but i'd stick with AS line. to be safe. scionsession_maui 07-24-2007, 07:29 PM wassup everybody...jus wondering and trying to get info for us maui peeps wanting to cruise oahu when the ferry comes? do we need a recon sticker for our rides? please if anybody has any info for uspm me or holla at me on myspace! thanks! |
