help with "maint required" light, i did search,
Old Jun 27, 2007 | 09:09 PM
beedee's Avatar
Default help with "maint required" light, i did search,
i did search and found info on the 05 and 06 models, but didnt see anything on the 07's relating to resetting the "maint required" light.
my odometer just turned 10k and around 9750 or so, the light came on. i took it to the dealer right around the 4500 mile mark for the first oil change. then, i went to my friends shop and did it there for the second oil change around 7500 miles. i've read that the light is scheduled to illuminate more or less at specific mileage markers.
i tried resetting myself by doing th "ign-on, ign-off, hold down reset button, ign-on until the dash or "s" and dash appear and then start the car once the "maint required" light stops blinking but i havent had any luck.
is there a different method for doing this on the 07's?
Old Jun 27, 2007 | 09:19 PM
SicktC06's Avatar
Did you read the Owners Manual?
Old Jun 27, 2007 | 09:31 PM
beedee's Avatar
i did awhile back, i'll have to go home and dig it out and see what i can find. just thought someone might be able to help me out on here.
Old Jun 27, 2007 | 10:25 PM
jaxtcracer's Avatar
yeah i'm pretty sure there's a procedure to follow in the owner's manual. good luck
Old Jun 27, 2007 | 10:49 PM
Hyghgynx's Avatar
The "s-off" "s-on" function is for the needle jump when you start the car. You want this one...
http://home.cfl.rr.com/icdedppl/faq.html
(Section C, question #7.)
Old Jun 27, 2007 | 10:58 PM
SquallLHeart's Avatar
you want the odo to read the odo when you start the procedure..
Old Jun 27, 2007 | 11:35 PM
beedee's Avatar
thanks for the lynx Hyghgynx, i'll give it a shot when i leave work tonight.
Old Jun 28, 2007 | 12:25 AM
Neversat's Avatar
I used this procedure just the other day and it worked fine, I have an 07, just passed 8k miles
Old Jun 28, 2007 | 12:59 AM
he did it right.. sorta.. just started off wrong.
it's pretty much a universal procedure that works on different makes and models..
i've reset that light for cars outside toyota as well in that same fashion
Old Jun 28, 2007 | 01:31 AM
emptystreets130's Avatar
Trip has to read odo. Turn car off, press and hold the odo button. While holding odo button, turn key to "ON" and wait til the odo flash. Let go of button, turn car off, and turn back on, maint. light should go away.
Old Jun 28, 2007 | 01:42 AM
Shocker's Avatar
Good stuff... helped me reinitialize the tire pressure warning system after i got my toyo proxes4 put on today.
Old Jun 28, 2007 | 06:09 AM
beedee's Avatar
yup, it worked like a charm, thanks guys.
NewBox06
Feb 3, 2015 12:36 PM
nastytc
Scion tC 2G Aero & Exterior
Jan 27, 2015 03:50 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
amart
Scion xD Aero & Exterior
Dec 23, 2014 12:06 PM
