Nitrous jetting
Old Jun 27, 2007 | 10:31 PM
streetlethalxb's Avatar
Default Nitrous jetting
So for you spray users.. I gotta question, if you know.. does a 50 jet, actually compute to that, or is the shot actually greater or smaller.. I just was thinkin' about it, and I wasnt able to work out if a 50 jet on a v-8 engine, and a 50 jet on a 4 cyl. would still be 50 for either.. scince they are sold only as rated jets, and not rated jets for the application.. Thanks!
I do understand the jet rating, is at best a scientific guestimate, but i'm looking for a better idea on what jets will do what on our 4cyl's.
Old Jun 28, 2007 | 12:32 AM
frogbox's Avatar
Default Re: Nitrous jetting
in a word, not really. you must also compute in tank pressure,temp and amount of fuel.
the jetting for nitrous settings are all guesstimates and approximations
when I first set mine up the jets for a 50 were too much ( fresh,warm tank, not enough fuel) she ran like poop.
second set up with a 35 jetting just right ( warm tank,proper fuel, proper plugs) does an 80 to 120 mph jump in a little over 3 seconds. :D
Old Jun 28, 2007 | 12:49 AM
okay.. perfect.. thanks!
what plugs did you wind up using?
Old Jun 28, 2007 | 04:43 AM
frogbox's Avatar
you can get away using anything but iridium and platinum.
both have a tedency to have a bad chemical reaction to the nitrous. they burn too hot as well. I use just plain old copper ( stock) plugs 1 step colder when I know I'll be juicing.
Zex has plugs they recomend , OBX ( eeewwww) does have 1,so do most of the other companies that have kits out.
but plainold copper works best for me, you just change them more often , like you change your bottle so changer your plugs.
Old Jul 9, 2007 | 05:21 PM
awdisuzu's Avatar
I use ngk iridium plugs with a 50 shot and it's awesome. I also run 91 octane gas, and so far it's been no problem. zex wet kit.
Old Jul 9, 2007 | 10:18 PM
awsome.. thanks!!
Old Jul 11, 2007 | 06:06 PM
autopainter13's Avatar
i was told not to use iriduim plugs with nitrous by my engine guy. i didnt ask why, cause he knows more than i do
Old Jul 11, 2007 | 09:18 PM
frogbox's Avatar
platinum plugs have a chemical reaction with the nitrous.anyone reading this have an rc car that runs on nitro? anyway the reason for non-platinum plugs is a reaction similar to the glow plug ( coil made of platinum reacts with nitromethane causing heat/spark to make the engine run)
same with iridium , so you wouldn't want that reaction in your engine (, pre-ignition with the nitrous ) causing unwanted effects.
simply put knocking and pinging leading to premature engine failure.
Old Jul 12, 2007 | 07:00 PM
awdisuzu's Avatar
platinum plugs retain a lot of heat in a very small "hot spot" which gives better performance and mpg under normal circumstances but it will preignite a NOS mixture. iridium plugs do not do this, and in fact they are recommended over stock for nitrous.
I also run a 250 shot in my dodge ram srt-10 (viper engine) with the same iridium plugs. I had problems with the stock plugs and even had a decent nitrous backfire which blew my intake airbox apart!
the problem was fixed by putting in the iridium plugs (2 steps colder also)
Old Jul 12, 2007 | 07:15 PM
NeoXa's Avatar
=/ From being a little nitrous happy I ended up going to a shop down here in florida, it was run by a bunch of older muscle heads.. all had old gto's or camaro's on HUGE shots of spray.
I kinda took this from them... Stock plugs or NGK plugs work the best..always a step or two colder then stock. The safest way for the average car person is to run a wet shot.. I had the best results and always felt a little safer..running the wet shot with a richer fuel jet. kinda elimiates some of the doubts of going boom. lol.
Colder plugs + spray + rich shot of fuel..and probably run 93 oct too... that does help a little.
Old Jul 17, 2007 | 03:58 AM
mk4umha's Avatar
A 50 shot? that's a bit too small, you need 75 or more.
Old Jul 17, 2007 | 04:20 AM
comedykills's Avatar
ScionERA
Scionetics
ummmmmmm yeah if you want to buy a new engine
Old Jul 17, 2007 | 09:54 PM
awdisuzu's Avatar
i didn't go over a 50 shot in mine due to the tiny sized rods.
yhwhdesign
Mar 7, 2015 02:01 AM
spawnconnery
Dec 18, 2014 08:38 PM
aarontrini85
37
Jan 24, 2009 03:21 AM
Tartman
9
Apr 16, 2005 03:26 AM
