NA setup anyone?
Old Sep 29, 2004 | 07:44 AM
hahaitzskippy's Avatar
Default NA setup anyone?
is anyone else going for the NA scene... besides me?
Old Sep 29, 2004 | 12:10 PM
fearturtle44's Avatar
Old Sep 29, 2004 | 12:27 PM
wOoOzZy's Avatar
NA = Naturaly Aspirated (ie: no forced induction such as turbos/superchargers).
Old Sep 29, 2004 | 06:06 PM
chucksu's Avatar
That might take some time. Also with the engine not having the VVTL-i, I dont think a NA set up would be worth the cost of money. You would be looking at head gaskets, pistons, rods, crank, valve job, intake, exhaust, cams, computer, & some other things. I just dont see the cost of doing a NA build up on a tC, to be worth it.
Old Sep 30, 2004 | 05:08 PM
well, considering the fact that the compression ratio is 9.6:1...
that is really low so if you were to increase the pressure to say 11.1:1, there would be a but HP gain. probably an NA setup isnt going to be as quick as a turbo setup but if you know wat your doin... then it woudnt be so expensive compared to a turbo. im lookin to reach 14's or 13's faster woud be nice but i think for your daily and mtn/track racer... thats enough power
Old Sep 30, 2004 | 05:17 PM
DeeM3's Avatar
So would a swap from a celica GTS work with the tC?
Old Sep 30, 2004 | 06:32 PM
MrJohnson's Avatar
When you up your compression you loose torque.
Old Sep 30, 2004 | 09:01 PM
chucksu's Avatar
:? With money any thing could happen. I would not do this swap though. That engine would kill itself in the 2,900Lb tC. It does not have much low end torque.
Old Sep 30, 2004 | 09:02 PM
chucksu's Avatar
How is that? TQ is what counts, if you lose TQ, then you lose HP seeing HP is just figured out by taking your TQ numbers & doing some math with them.
Old Sep 30, 2004 | 11:05 PM
iowagary's Avatar
What exactly is Naturally Aspirated, as opposed to what the tC comes with stock? I always thought it was just the lack of a turbo or super charger (anything "forced induction"). So what would you have to change to make a stock tC naturally aspirated?
Old Sep 30, 2004 | 11:51 PM
chucksu's Avatar
Yes. A tC is a N/A car. It comes stock as a N/A car. What he is saying by a N/A tuning is making the engine produce gobs more power with out the aid of Forced Induction.
Old Oct 1, 2004 | 05:50 PM
man chucksu hahaha check out all your posts hahaha
increased compression is not losing TQ. for example: PSI = boost = raising compression in a cylinder = increase HP n TQ. so raising compression with out FI woud result in the same manner.
also considering the relatively low compression ratio of 9.6:1, this car has a lot of potential to add lots of boost or raise its compression. only question is if the engine can handle it.
chucksu i was thinkin about your post on the VVTL-i cams. it might be possible to do a swap? or a 2AZ comversion to have serveral components frum the 2ZZ. SCC had an article on this but it was on a honda. they took a acura TSX n swaped heads with a RSX type 2. so they used a K24 block with a K20A2 head and cams. done deal. and cof course a stand alone ECU to accomdate. and the new engined pumped out 180whp instead of 140whp. crazy stuff
and again... with money everything is possible. i jus really hope i can do such a swap.
Old Oct 1, 2004 | 05:59 PM
chucksu's Avatar
Yeah im not sure if a head swap, or parts from the head could be done. I think they are 2 different engine series. I think the best bet is wait & see for a while. Even with out a VVTL-i set up, you should be able to get some good power from the engine. Seeing Im going into the air force soon, I already got a good deal of my car mags packed :oops:. One of them had this face off of a few different Civic HB's running the K20 engine. Skunk Racing took the engine & got a little over 200hp to the ground doing a N/A build up. Now that does use V-TEC, but its only a 2L engine. So I think the added .4L of the tC engine could make up for the lack of a Lift feature.
Take the CR up to around 11:1 & run 92 octane. All the other things & wait & see if some company makes some rods, pistons, cams etc.. Also a bigger TB & things like that might help. Might even be able to build a slight ram air style system, might be good for a little extra power when at speed because of the cooler air.
vi3tb0i09
Sep 23, 2015 08:32 PM
Subaru86
Sep 14, 2015 12:51 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
Sep 13, 2015 04:39 PM
dbg326
Aug 28, 2015 05:18 PM
Subaru86
Jul 31, 2015 04:33 AM
