Nick06tC
06-30-2007, 06:57 PM
Recieved my Corbeau A4s the other day and installed them last night and today.
Whats everyone think?
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1886.jpg
here is a DIY to help people out.
Its fairly simple and if done at once should only take about an hour. (i was busy so did it when i had time)
(I am not responsible for any damage, or laws broken by messing with the airbag system)
1 Ratchet
1 14 MM socket
Start by pushing your seats all the way back. There are 2 bolts up front that need removed with a 14MM socket. Remove the two bolts shown.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1854.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1855.jpg
Once they are removed. Push the seat all the way forward and tilt the seat forward. There are two covers in the back that need popped off. Once popped off, they reveal 3 bolts. remove with a 14 MM socket.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1856.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1857.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1858.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1859.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1860.jpg
With the 5 bolts removed the seat is loose. DO NOT PULL IT OUT. Lean the seat back and you will see a wiring harness going to under the seat. The harnesses are for the airbag monitoring system. Disconnect the plugs.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1861.jpg
Pull the seats out of the car.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1862.jpg
Good time to vacume the car. i didnt because its just to hot and muggy outside.
You can see where the mounting bracket will go. On the Corbeau mounts I recieved they are labeled backwards. The passenger is really the driver side. And driver passenger side. To tell, look for the side that has the extra hole for the bolt going into the center console transmission well.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1864.jpg
The mounts, mount to the seat before mounting to the floor. The allen wrench is provided with the seats if purchased brand new. I found mine after install tapped to the bubble wrap. Unscrew the four allens from the seat bottoms. The seats are not the same, there is one for driver and one for passenger, you can tell by the side the seat tilt is on.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1865.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1866.jpg
Move the rails all the way forward to attach the rear bolt. Then slide all the way back to get the front bolt. Make sure they are really tight so the seat doesnt move.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1867.jpg
In the stock seats, you will need to remove the seatbelt assembly, and the airbag harness. I didnt remove the sensor for the seat cushion yet, but I will. simply unbolt the seat belt harness with a 14 MM socket. Un-attach the clips for the harness.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1871.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1872.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1873.jpg
Attach the seatbelt to the new seat on the spplied bracket. Run the wiring under the seat.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1874.jpg
Put the seat in the car. Tilt the seat backwards and hook up the harness back to the car.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1875.jpg
Resecure the seat with the 5 bolts you removed. Make sure they are secure for safety purposes.
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1876.jpg
Before and after pics:
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1852.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1869.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1870.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1877.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1878.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1879.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1884.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1885.jpg
http://i24.photobucket.com/albums/c25/nick120580/car/New%20Seats%20and%20Navi/IMG_1887.jpg
1 Ratchet
1 14 MM socket
