View Full Version : OEM Lip Spoiler Install
Makaveli
07-01-2007, 10:59 PM
Anyone in SoCal know how to or a place that can do it for a fair price? I'm planning to get one, just don't have the tools or the guts to install it.
mcheng08
07-01-2007, 11:44 PM
just install the spoiler using this technique, very easy and no holes in your car. http://www.scionlife.com/forums/viewtopic.php?p=1071996#1071996
brian
07-01-2007, 11:50 PM
i used double sided tape to install mine like the above link. the install is easy and even if you don't have tools, just buy some and you'll still come out on top. the only tool i needed was a dremel.
Makaveli
07-02-2007, 12:02 AM
I saw that tutorial before. There is a reason why there are bolts, security. Bolts are the most secure way to mount a spoiler, bottom line. it will withstand lots of pressure, water, and is the proper way to do it. Even with 3M tape I can't guarantee the same.
brian
07-02-2007, 12:05 AM
it's probably one of the easiest things to install on your car if you'd like to install it that way be my guest. you just drill a couple holes and you're pretty much done, no special tools required so you should have everything you need already.
mcheng08
07-02-2007, 12:11 AM
the 3M tape are extremely strong, i have pressure washed my car several times and it is still holding strong. just make sure you buy the automotive 3M tape, and you will be fine.
