Alternator removal and fitment questions..
Old Jul 4, 2007 | 03:39 AM
hotboxn's Avatar
Team Echo
Default Alternator removal and fitment questions..
I'm going to be swapping out my Alternator next week and was wondering where the belt tentioner was on our xB's. Is it hard to pull the alternator?
Also, does anyone know if an Alternator off of a 91-92 MR2 will fit in our stock location and work properly?
Are there any other cars that have the same size location as we do so that I could install something larger?
I know I can have the Alternator respun and add about 15 more amps, but that isn't much.
Any help will be much appreciated.
__________________
Old Jul 4, 2007 | 01:50 PM
hotboxn's Avatar
Team Echo
anyone got any ideas???
Old Jul 5, 2007 | 10:45 PM
jct's Avatar
jct
theres no belt tentioner, getting the bottom bolt out on the alt is pretty hard from what i hear
Old Jul 7, 2007 | 12:51 AM
Scorpius01's Avatar
Here is the trick, pull out the top bolt, and the bracket. Push the alternator as far forward as you can (the direction to loosen the belt), now you have room to get the bottom bolt out, easier.
top bolt 12mm
bottom bolt 14mm
Old Jul 16, 2007 | 11:48 AM
EasysBox's Avatar
if you are still wondering how to do it, the easiest way is to remove the front bumper, then remove the windshield washer reservoir, then you have a clear shot at the bottom bolt, use an impact gun and an extension if you have access, it makes getting the bolt out a lot easier.
Old Jul 16, 2007 | 11:57 PM
Scorpius01's Avatar
Why take off that much? That takes too much time and is very unnessacary.
Old Jul 18, 2007 | 05:47 AM
EasysBox's Avatar
i almost stripped the bolt trying to rock the alternator like you said to do, and get a tool in to remove the bolt in that cramped space, enven when i removed the bumper, which takes a mere 5-10mins, and had a straight shot at the bolt, it was starting to strip with a socket, the impact gun was the only thing i could use to take it off without stripping it.
Old Jul 19, 2007 | 07:46 AM
itsme's Avatar
IMHO taking steps that may take longer would make things easier and lesser chance of a headache from something breaking and what not........i normally take off my front bumper and stuff when i do things like when i changed out my clutch........
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
CPL_Radar
Mar 5, 2015 05:42 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
