really newb gauge Q
Old Jul 4, 2007 | 07:11 PM
sciontc07's Avatar
Default really newb gauge Q
ok i know this is newb and it might be in the searches....but that takes too long and i have an opportunity to purchase it right now...so please help.....what are the most typical gauges on a F/I car....1.boost 2. ??? 3. ??? ......one is oil right? and the last?....thanks!
Old Jul 4, 2007 | 07:13 PM
318_tC's Avatar
boost, egt, oil, wideband, fuel pressure (if u have a return fuel system i advise)
Old Jul 4, 2007 | 07:16 PM
sciontc07's Avatar
ok i think i might get a 3 gauge pillar....unless u got another suggestion....im getting the Tru-boost...so thats a boost gauge already....now what 3 gauge should i get for the pod? and what is egt? SORRY....
Old Jul 4, 2007 | 08:42 PM
bruceg's Avatar
The three most important are: Boost, Oil Pressure, and Air/Fuel Ratio.
Old Jul 4, 2007 | 11:24 PM
20tCDude05's Avatar
I got the Defi Blue Racer Boost Gauge, Defi Blue Racer Oil Pressure Gauge, Defi
Blue Racer EGT (Exhaust Gas Temperature) Gauge, AEM UEGO Wideband Gauge.
Reasons why important:
Boost: To be able to see if you boost spike or have any boost creeps for performance awareness.
Oil Presure: Lack of pressure can damage your motor. So, if pressure goes down, check oil feed lines.
EGT: Too hot means engine is overheating and too cool means engine is not performing as well as it could be.
A/F Wideband: It shows if you`re running too lean or too rich. 11.5-12.5 is ideal for boosted applications.
Old Jul 4, 2007 | 11:39 PM
Brett's Avatar
where did you get this info???
EGT: too hot actually means that the air/fuel mix is lean, and too cold means its rich.
i would shoot for a tune between 11.2-11.8. 12.5 would be pushing it.
Old Jul 4, 2007 | 11:42 PM
sciontc07's Avatar
AEM UEGO Wideband Gauge => isnt that the same as the air/fuel ratio gauge?
Old Jul 5, 2007 | 12:10 AM
20tCDude05's Avatar
where did you get this info???[/b]
Not you again........
Old Jul 5, 2007 | 12:13 AM
20tCDude05's Avatar
Yes, it is. It is top of the line gauge. I will put mine in the cubby.
Old Jul 5, 2007 | 01:01 AM
sciontc07's Avatar
cant i just get a cheapo autometer or glowshift guge that is the air/fuel and it will be efficient but maybe not as good?
Old Jul 5, 2007 | 03:01 AM
sciontc07's Avatar
no problem with it right? because i can buy one soon for cheap...but from glowshift gauge
air/fuel
Old Jul 5, 2007 | 03:05 AM
bruceg's Avatar
Well, you just have to make sure it's a WIDEband gauge
Old Jul 5, 2007 | 03:15 AM
sciontc07's Avatar
sorry but now im confused...
that other guy said that the AEM Wideband gauge is the same as the air/fuel gauge
but u said it has to be a WIDEBAND...
so should i purchase the airfuel gauge?....
confused...
Old Jul 5, 2007 | 03:20 AM
20tCDude05's Avatar
GlowShift Gauges are much more cheaper and inaccurate than the AEM one. Wideband is something serious to keep an eye on as it can mess your motor up if it`s way too lean or rich.
Old Jul 5, 2007 | 05:07 AM
bruceg's Avatar
confused...
Yes, AEM Wideband measures Air/Fuel ratio
When you buy your gauges (if for some reason you do not choose the AEM gauge) jsut make sure you get a WIDEband gauge and not narrowband, narrowband gauges do nothing for our cars.
Wideband and narrow band are both air fuel ratio tho.
Old Jul 5, 2007 | 05:14 AM
20tCDude05's Avatar
Just don`t cheap out and get the AEM UEGO Wideband Gauge, period. End of story. It will be money well spent.
$300 or a $3000 motor, up to you...
Old Jul 5, 2007 | 05:43 AM
sciontc07's Avatar
so glowshift is really that bad huh? just might as well put a hold on installation and get money for the wideband first?
Old Jul 5, 2007 | 07:18 AM
Mr_Meaty's Avatar
Do you already have a turbo kit? You just don't have it installed yet?
Old Jul 5, 2007 | 08:00 AM
sciontc07's Avatar
that is right
Old Jul 5, 2007 | 04:23 PM
bruceg's Avatar
Dang man, it must SUCK to have the kit and be itching to put it on.
But don't rush it man, make sure you get good gauges and sh*t first or you'll regret it alter.
Anyways, good luck with the gauges and the install man!
