View Poll Results: Better Turbo Kit?
Voters: 50. You may not vote on this poll
Im Confused....ZPI and Dezod.
I checked out ZPI and Dezod to try and see whats the difference between the ZPI Stage 1 and the Dezod Kit. I found out they both give you bout 300whp. They both cost around 4500 bux. There both bolt on. They both claim to have gotten low 12's in 1/4 miles. So there pretty much dead even. But im confused because Dezod says you need to replace clutch which is fine and I can understand that. But ZPI says that his kit will prove to be very reliable on the stock block and clutch. I was wondering how is that possible with the same specs as the Dezod kit pretty much and you dont have to replace clutch. Youll tear that clutch up the first time you pull it out of the driveway. I dont know im just confused.
boosted with dezod, 10k w/ kit, 33k on car (stock clutch). it really just depends on the driver rather than the kit.
if i had zpi, i would still also be on stock clutch so its really how YOU drive the car that depends how fast your clutch will last.
Even if you were not boosted, you might need a new clutch depending on how you drive. With either kit, you are most likely going to need a new clutch sooner or later. Dezod just tells you so. The choice is yours.
Originally Posted by KillaSpiceTSW
Honestly do you ever race it. Or push it hard. Is Dezod just saying that just to be on the safe side. Better safe then sorry type of deal. Thanks
personally, i drive my car hard but don't shift hard cuz i'm still on stock clutch. shifting hard just puts unnecessary wear on your clutch so i don't bother doing it. i don't drag cuz our track closed down here. i do autocross but i pretty much just shift into 2nd and leave it there for the whole run.
Clutch is up to you if you wanna replace it. It won't have to be replaced at first but like someone said eventually it will need to be. I didn't replace mine and it worked fine for 4 months in city driving and then started to slip in 2nd a little.
As for who kit's better there's so many things to compare and that is different and 900 of these post so look it up.
I would like to know who made low 12s with a dezod kit or even 12s.
Bolt on S1 with 16 PSI on street 18" wheels
Jeff's slip
yea you might need a new clutch not because of the kit you choose but because you are going
F/I and more power/more torque more stress to the clutch. You might be able to use stock clutch for a while if you are not doing aggressive driving. Just remember to learn a good knowledge bout F/I when you get a turbo cause thats gonna be your friend when things goes bad.. both are good but i like dezod more..
what causes the axle to snap by the way? is it bad driving or too much power?
Originally Posted by Mr_Meaty
Remember that one they snapped the axle on?
This is before he bastardized his car by mixing companies, right?
But after the auto to manual swap?
Jeff's slip
Isn't that on a built motor though
Originally Posted by djafropiq
jeff did.. (318_tc) right? or are we talking about non built motors?
The record still stands on a NON-built motor with ZPI kit still having top honors when it comes to flat out "Smoke you on the street and track" performance, with a LOW 12 sec run, not mid, not high. Low 12's (12.1) to be exact. ZPI entered the 12sec record books over 2 years ago. And even their customers have ran 12's on stock motor. The first 12sec slip from Dezod has come recently by way of 318_tC, on his built motor tC. His average was low 13's with a dip into the 12's.
I now have experience with the Dezod Kit (as a crew member of ours has one now). Very good looking kit imo. IF you are more into looks, the Dezod kit is very "show worthy" evne in raw (uncoated pipe) form, and will pull some trophies at the car shows imo. But if you are more into racing, then ZPI kit is going to take honors in that department over Dezod. The smaller 16G spools a lot faster, and puts you in the seat a lot more imo, because of it's lag free nature. The smaller turbo that ZPI uses as the strong points (pumps out the same HP as the larger Dezod Turbo at the same PSI settings), but does not have it's weakness (laggy Dezod larger turbo).
The Poll results is largely based on Customer Service, and not Product Performance. Of those 17 votes, I would be surprised that not all of those votes are of people who actually have the Dezod kit. Dezod's Customer Service is excellent, so that is a heavy contribution to the voting taking place here. ZPI's shipping times have slowed down recently, so if you are willing to wait for it, you will have one of the most highly regarded turbo kit available for the tC. That is if you are willing to wait the extra time to receive it. If you specified a little more on what your goals with the turbo kit are, then you perhaps would get a more narrow straight forward opinion on which turbo kit to go with.
And just FYI.....GET a clucth, I don't care what anyone says.
