xA Shortshifter question
Old Jul 10, 2007 | 04:05 AM
WRxB's Avatar
Defined3
Default xA Shortshifter question
Just a quick question & sorry if this has been covered already.
Just bought my xA today so I am kind of a xA noob I guess.
Is the shifter in the xB & xA interchangable ?
I had an RS-Type in my old xB & liked it but it isn't showing an xA for the part. I tried contacting a seller a week ago & got no response. All of the xA ones I have seen are just the shifter post & not the shifter w/ the cage, where as the RS-Type has the cage & that is what is throwing me off.
Thanks in advance for anyone that can shed a lil light on this.
Old Jul 10, 2007 | 04:17 AM
Persocon's Avatar
i have a rs-type with the cage, bought it for xA from the start, i still have the box. we can check part numbers or something
Old Jul 10, 2007 | 04:30 AM
WRxB's Avatar
Defined3
The only think they have on the site is RST TSC1
It is on www.scionsport.com in the xB section
Thank you for your help :-)
Old Jul 10, 2007 | 04:38 AM
Persocon's Avatar
my box says SS-TCS1 give me the dimensions? i dunno BUT my box does show a picture of a Civic Si on it
Old Jul 10, 2007 | 02:28 PM
JSosa's Avatar
ok ive installed 3 short shifters on my car before finally getting a decent one. The first one i purchased was a cheapy eBay POS. The shift change was about 20%, which is virtually nothing and the cage was so badly made that shifting was like trying to put a square peg in a round hole. The second one was the TRD original, which included the cage, but was incredibly overpriced, the throw was once again a 20% difference, but this one actually shifted correctly and felt smooth. Then recently i wanted something more aggresive, so i looked at Perrin Performance and their adjustable short throw. This one doesn't have a cage and switching out the shift rod was a pain in the a$$, but worth every single bad word that came out of my mouth during the install. You can adjust from 20%-200% and thats a BIG difference. I wouldn't switch it for the world.
If you want a GOOD shifter with a cage go TRD, dont buy any cheap rip-offs, like on the SSuperstore.com, you can get the same one on eBay for $25.00. Its NOT NOT NOT worth it. Of course its affordable and a breeze to install, but its up to you.
Old Jul 10, 2007 | 05:45 PM
IH8ONYU's Avatar
just get a good adjustable shifter, and re-use the old cage. it is a pain to swap out, but worth it.. all you need to do is go to your local hardware store and get a disked washer or a c ring.... see install instructions for cravenspeed short shifter or any other short shifter install article in the tech section..
overall, it took me 45 min to change mine out, including time to run to hardware store, buy longer bolts, and washers to shim my cage up... dunno if you will have this issue in the xa though.. you may need to shim, you may not..
Old Jul 10, 2007 | 08:04 PM
WRxB's Avatar
Defined3
Thanks for all the good info. I am going to look into everything you all posted. I will let you know what I decided on & how it turns out.
Thanks again :D
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
