View Full Version : Tire Pressure Sensor Recalibration
mikochu
10-04-2004, 11:01 PM
Contributed by BlueBox.
Use this procedure to recalibrate aftermarket wheels/tires on the tC:
1) Turn ur engine on
2) Set the E-Brake (pull up)
3) Press and hold the tire "reset" button in the glove box
a) The tire pressure sensor light should blink 3 times consecutively
4) You must drive the vehicle for about 10 miles without turning off the engine. This will recalibrate the tire pressure sensor.
xAlex
10-30-2004, 03:47 PM
is there anything like that for the xA?
mikochu
10-30-2004, 06:04 PM
Nope... Just get one of those nifty tire gauges with the bleed valve and check your tire pressure every month or so...
stillkicking47
11-02-2004, 04:55 AM
What is this for?
SuperCrunchyAction
11-03-2004, 05:11 PM
What is this for?
"Use this procedure to recalibrate aftermarket wheels/tires on the tC: "
05idinktc
12-15-2004, 04:23 PM
it goes the same for the stock wheels right?
TurboMe
03-05-2005, 04:55 AM
wheres the tire pressure gauge? :D
yesti
07-24-2005, 01:51 AM
been thinking about this and does anyone know the threshold for the tire pressure warning to trigger +/-psi? and is it part of the abs system meaning would the abs come on sooner or later depending on what the pressure was 'set' to versus what it actually is? like if you pump the tires up to 51psi cold, set the system then bleed them out to 40 would that affect abs activation in any way? i'd try it but my commute to work is only ~8 miles (and takes 30-45 min!) crawling on the freeway.
jsingh
05-21-2008, 12:02 AM
what is recalibration?
Sciond
05-21-2008, 01:13 AM
hmm why is this here still holy old threads
