Megan Header
Old Jul 19, 2007 | 05:23 AM
Baolao10's Avatar
Default Megan Header
I just installed a megan header on my 05 scion tc and at first the check engine light didn't come on, but after driving it around for 2 days and it happened when I turned on my A/C. I restarted my battery and the check engine light went away, but when I turned on my heat the check engine light came back on. Could someone please let me know what I'm doing wrong. I got my header proffesionally installed at Monroe.
Old Jul 19, 2007 | 11:48 AM
ack154's Avatar
Did you use any sort of antifouler with your O2 sensor? Search for it if you didn't... you'll get a lot of results. Or check the tech section.
Old Jul 19, 2007 | 01:53 PM
Baolao10's Avatar
Default Header
what's an antifouler? I just unplugged my old o2 sensor and plugged it backed into the new header? where would i find the tech section?
Thank You,
Mina
Old Jul 19, 2007 | 01:55 PM
azepolyn's Avatar
at the top. Features > Tech
https://www.scionlife.com/tech/
Old Jul 19, 2007 | 02:13 PM
ack154's Avatar
Yup. And there's a red search button that the top of the page too.
Old Jul 19, 2007 | 03:48 PM
Sleep3r's Avatar
dont forget with megan i heard you gotta use 3 foulers if 2 dont work
Old Jul 19, 2007 | 04:10 PM
Baolao10's Avatar
Default megan header
Thanks I saw the pics. I thought there were only two o2 sensors on the header where's the 3rd one??
Old Jul 19, 2007 | 04:42 PM
Sleep3r's Avatar
there is one o2 on the header where you DONT put a antifouler on and the other is on the S-pipe where the antifouler trick needs to be done
Old Jul 22, 2007 | 08:12 PM
Baolao10's Avatar
Default 05 Scion TC
I just installed a TRD axle back exhaust and it's very very loud and rattles alot when I gas it... I heard it was not supposed to be as loud as the Injen exhaust which was my last exhaust i had on. I don't know if this is from the meagan header I have in the engine or should I just put the stock header back in?
Old Jul 22, 2007 | 08:14 PM
Baolao10's Avatar
Default Meagan header
Thanks for the tip on the anti-fouler. It worked.. I appreciate it very much..
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
kslim619
Sep 18, 2015 06:54 PM
Nkelly
Sep 7, 2015 05:06 PM
