Hi Flow Cat vs. Cat Delete down pipes
Old Jul 20, 2007 | 02:01 AM
Cyrus_tC's Avatar
Default Hi Flow Cat vs. Cat Delete down pipes
What has the bigger yield?
Old Jul 20, 2007 | 02:27 AM
tCtCtC's Avatar
*watching*
Old Jul 20, 2007 | 03:57 PM
Sleep3r's Avatar
i dont think there is really a big significant difference between the two
Old Jul 20, 2007 | 04:14 PM
Cyrus_tC's Avatar
Well.. if there isn't one that is better performance wise.. how about economically? obviously the cat?
Old Jul 20, 2007 | 05:27 PM
Sleep3r's Avatar
yeah when you delete your cat (esp. both cats) your car will smell like crap
Old Jul 20, 2007 | 08:18 PM
dlindberg2nd's Avatar
where would you get a high flow cat?
Old Jul 20, 2007 | 08:55 PM
Cyrus_tC's Avatar
the intraweb :p
Old Jul 20, 2007 | 08:57 PM
Sleep3r's Avatar
you can go to magnaflow's website, everyone been using the magnaflow hi-flow cat but i forgot what the part number was
Old Jul 21, 2007 | 04:30 PM
tC-JDM's Avatar
in the mid-pipe there is 2 resenators right????
when you change the header you delete the cat.....
Old Jul 21, 2007 | 04:56 PM
Sleep3r's Avatar
no there is only one resonator, there is another cat in the midpipe
Old Jul 21, 2007 | 10:10 PM
Cyrus_tC's Avatar
My main concern was with just the actual cat in the midpipe.
hi flow or delete?
Old Jul 21, 2007 | 10:12 PM
tC9o9's Avatar
the actual cat is in the header, the cat on the midpipe is a secondary cat and just catches what the first one doesnt.
replacing that will not yield any "good" results, your better off getting a header.
also, deleting both cats is a VERY good way to get pulled over, the smell and the white smoke blowing out of your tailpipe are easy give aways your car is modded.
Old Jul 22, 2007 | 03:07 AM
Cyrus_tC's Avatar
ok.. but my question isn't about what i should replace. I eventually want TB.. dezod spec . I don't want a cat delete so what are my options as far as hi flow secondary cats - in case the manifold has a cat delete in the kit
Old Jul 22, 2007 | 05:12 AM
tC9o9's Avatar
any aftermarket manifold will delete the cat.
the only aftermarket cats that i recommend are vibrant and magnaflow, in that order.
Old Jul 22, 2007 | 09:23 AM
Cyrus_tC's Avatar
thanks 909
Old Jul 22, 2007 | 09:48 AM
fujita_TC's Avatar
yea i have header back exhaust, no cats, and i tell u it smells like crap, thats why my friend doesnt want to roll behind me when we roll together,
yea no cats= auto sniff test fail.....
Old Jul 24, 2007 | 02:59 AM
ESEMRFOZZ13's Avatar
no cat has best power but metalic high flow cat is 1 hp less but good priced.$$$. get megan, it looks like thiers a cat but thier isn't. import tuner.com has these resulsts posted with dyno on a civic
Old Aug 24, 2007 | 08:37 AM
Imperial's Avatar
Check this article out about going catless. Should shed some light on the issue.
http://images.magnaflow.com/05news/m.../catalytic.pdf
Old Aug 24, 2007 | 10:26 AM
Griever's Avatar
Question... Will only having the secondary cat in the midpipe keep my exhaust from smelling like butt? :o I'm installing my DC header and megan s-pipe this weekend
Old Aug 24, 2007 | 03:54 PM
Sleep3r's Avatar
^^ yes
