View Poll Results: WHAT color do you want ?
Green
15.56%
Red
15.56%
Blue
20.00%
White
31.11%
Orange
6.67%
Uv
11.11%
Voters: 45. You may not vote on this poll
A/C led MOD HOW2 plug n play kit by EZ-BAKED
Old Jul 20, 2007 | 01:45 PM
EZ-BAKED's Avatar
Default A/C led MOD HOW2 plug n play kit by EZ-BAKED
billy@EZ-BAKEDCUSTOMZ.COM OR EZSLADY@EZ-BAKEDCUSTOMZ.COM
Installing the EZ-CUSTOMZ plug & play A/C LED kit
Ok so here is how I did it.
disconect the battery Take you time and dont brake anythig if you do dont blame me or SL. Ok now that we got that out of the way lets get started.
Step 1.
Remove the 3 a/c ***** by pulling them towards you.
Step 2.
Remove the 2 Phillips screws that are behind the a/c *****. One on the left one the right .
Step 3.
Remove the center dash panel. I find it EZ to remove the panel by putting the pointer finger from each hand in the outside holes where the a/c **** were and pulling the panel towards the center of the car. Once the bottom corners are lose, hinge the dash towards the ceiling .
Step 4.
Disconnect the 3 plugs attached to the back of the center dash panel and remove the panel.
Step 5.
Remove the 2 lights located next to the plugs one on each side.
Removing the buttons and controls from the panel.
Step 6.
Remove the 2 Phillips screws that holds the a/c and hazards buttons to the back of the panel.
Step 7.
Using your finger unclip the 2 tabs on the bottom.
Step 8.
Using your finger unclip the one tab on the top and remove the controls.
Installing the LED’s
Step 9.
Remove the clear plastic piece bridging across the whole panel face.
Step 10.
Now place the Led Flex strip around the center control with the LEDS facing the plastic window and replace the clear bridge.
Step 11.
Now fish the plugged ends of the rewired Super Flux 4 chip led threw the hole left from removing the light in step 5 .Fish the plug threw the front side so the plugs end up in the back of the whole panel.
Step 12.
You should now look like this.
Finding power and taping in
Step 13.
You can now reassemble the panel by snapping it all back together and replacing the 2 Phillips screws. Do not over tighten its only plastic.
Step 14.
Using the supplyed Scotch locks tap into some power. Place one tap on the all green wire and the other tap on the white wire with the green stripe. These wires can be found on the big plug that you unplugged from the A/C controls.
Step 15.
Plug the LED’s into the supplied plug harness and into the taps. Plug the black wire of the plug harness into the white wire with green stripe. Plug the red wire of the plug harness into the green wire. Reconnect all the plugs and reassemble the dash.Now when you turn on you lights you should have nice bright led glow.
colors we can have and what they look like
Old Jul 20, 2007 | 01:50 PM
evosky's Avatar
so tempting .. but i just dropped $$$ on suspension parts >_<
Old Jul 20, 2007 | 02:45 PM
BangorXB's Avatar
have a pic of the blue? i have the wedge bulbs in blue but it doesnt match the other blue leds i have behind the speedo and clock. i wanna see if this is closer. also the wedge bulbs are dim on the far ends of the dials
Old Jul 20, 2007 | 02:58 PM
EZ-BAKED's Avatar
thanks
no pics of the blue but they are leds so they should mach great. Blue is one of the brighter colors.
Old Jul 20, 2007 | 03:01 PM
xbizzle562's Avatar
I was also wondering on how the blue kit would looks like.
Old Jul 20, 2007 | 04:53 PM
samhain's Avatar
I want to see some pics of the install.
Old Jul 20, 2007 | 04:56 PM
EZ-BAKED's Avatar
EZ-BAKED's Avatar
how 2 install coming in the next few days.
Old Jul 20, 2007 | 05:05 PM
Breakfast_at_Tristans's Avatar
DeepSouth Scions
Hmm.. definitely watching... RED PLEASE!
Old Jul 20, 2007 | 07:23 PM
Ekolu2004's Avatar
wow!! i just got some led bulbs for mine and it doesn't look as bright as these... i'll wait for the install pics... VERY NICE i likey, also is it possible to do two colors?? or just one?
Old Jul 20, 2007 | 08:59 PM
Evil_Genius's Avatar
I want one for the xA! lol
Please?
Old Jul 21, 2007 | 12:20 AM
LeroyJMC's Avatar
Stated XB only, but is there any reason that they wouldn't work for the xA EZ-BAKED?
BTW...I've been seeing some of the stuff you're doing and truly admire your works.
Old Jul 21, 2007 | 12:44 AM
DarkBoxJr's Avatar
I'd really like to see how white looks.
Old Jul 31, 2007 | 05:20 AM
EZ-BAKED's Avatar
Old Jul 31, 2007 | 05:26 AM
jwaj2002's Avatar
TOCC
can't choose cause I want red/blue
Old Jul 31, 2007 | 02:13 PM
EZ-BAKED's Avatar
good morning bump
Old Jul 31, 2007 | 05:22 PM
aalbertson3's Avatar
Are the hot spots really that bad or is it just the picture?
Old Oct 22, 2007 | 08:01 PM
EZ-BAKED's Avatar
long time bump
Old Oct 23, 2007 | 10:31 PM
dmpsk8's Avatar
u gotta quit tempting me with all this ****. Im determined to hold out for the sonar fff
Old Oct 27, 2007 | 02:30 PM
EZ-BAKED's Avatar
b u m p
